FLB.SPL.EVENTS Posted November 20, 2011 Report Posted November 20, 2011 Obviously this is worse in other states, in AZ 98% of all competitors actually test on music, if you go to meca site and look at AZ shows, all those are on music, just how we roll, also why you don't see crazy scores lol with that said though, I absolutely support CASH prizes. Next seperate cars and truck and vans lol I hope this works, I would like to see it get big and come out west we have separated cars and SUV/Trucks for no wall. but not the other classes. we didnt want to break down too many classes. when the winner receives cash you want the most people in the class to get the most money. so if we made a ton of classes then there would be 2-3 cars in each class and no big money to win. the classes are also divided by cone area too.
Forevrbumpn Posted November 20, 2011 Report Posted November 20, 2011 A topic debated often. I kind of had an idea of an all out comp. Why end at cars/trucks? I always wanted to make a bass air cannon. Something like 5 subs firing into a small chamber firing in to a 10' 15 20' tube and meter at the exit or fire it in to a vehicle trailer just something. Cars are cool but the limits are so close to reaching absolute max physical limits I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
cf2004 Posted November 20, 2011 Report Posted November 20, 2011 I lose dbzz and the headrest....can ya change that rule....lol just joking......well not really.....:/
IH8PunkRok Posted November 20, 2011 Report Posted November 20, 2011 im gonna throw this out there. headrest metering, music, average the average shouldnt be very long though because as it is most people competing in these types of comps only use a few songs due to length i want to see this FLB league take off. it seems promising. and to teardrop^ if you want to be competitive rebuild your box under the window line if i did i would eather loos my back seat and or drop db because im doing a bamdpass box /4th order and it should be based on volts cone area and watts that way its down to the design and install not who can spend the most money thats not exactly fair either because then an extreme car with 2 15s and 1000 watts can go up against a non wall vehicle with two 15s and 1000 watts and ill bet the extreme vehicle spanks it pretty hard thats the thing with competitions. someone will always feel they were cheated. in the end it comes down to the fact that your competitor thought of something you didnt and that is why you lost. I really like the cash idea. Im gonna talk to a friend of mine that used to be a MECA judge, see if he can help set up a show in the Louisville KY area -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
kr15 Posted November 20, 2011 Report Posted November 20, 2011 the hard part is that if you truly leveled the playing field there would be too many classes, i.e trunk car, trunk car wall, trunk car 14+ volts, hatchback, hatchback wall hatchback 14+volts etc etc etc..I have a little trunk car and I am at the biggest disadvantge of there NOT being a bunch of classes, but thats better then have 40 classes per show...my main suggestion is headrest reading because i think it best simulates what a car sounds like and do a burp format for the fartboxers and a 30sec avg format for the daily drivers. Fuses really serve no purpose in leveling the playing field because we all know how to manipulate them. (A guy here on smd was burping 2 saz4500s on a single 30a fuse). 4ohm ratings are also useless because there are too many amps that are rated specifically for these purposes, i.e 500w at 4ohm but the damn thing does 5000w at 1ohm. Clamping power is the most fair way, but this could be time consuming....bottom line is that no orginization will ever be able to equally represent each type of build. Thats why I dont mind the fact that there are multiple orgs. If you like fartboxing, do dbdrag. If you like headrest readings do Meca, if you wanna clamp power, do MWSPL etc Team Flex Issues Low tuning > God 2011 CALI AS1 STATE CHAMP
FLB.SPL.EVENTS Posted November 21, 2011 Report Posted November 21, 2011 the hard part is that if you truly leveled the playing field there would be too many classes, i.e trunk car, trunk car wall, trunk car 14+ volts, hatchback, hatchback wall hatchback 14+volts etc etc etc..I have a little trunk car and I am at the biggest disadvantge of there NOT being a bunch of classes, but thats better then have 40 classes per show...my main suggestion is headrest reading because i think it best simulates what a car sounds like and do a burp format for the fartboxers and a 30sec avg format for the daily drivers. Fuses really serve no purpose in leveling the playing field because we all know how to manipulate them. (A guy here on smd was burping 2 saz4500s on a single 30a fuse). 4ohm ratings are also useless because there are too many amps that are rated specifically for these purposes, i.e 500w at 4ohm but the damn thing does 5000w at 1ohm. Clamping power is the most fair way, but this could be time consuming....bottom line is that no orginization will ever be able to equally represent each type of build. Thats why I dont mind the fact that there are multiple orgs. If you like fartboxing, do dbdrag. If you like headrest readings do Meca, if you wanna clamp power, do MWSPL etc you named it all right there. there will always be something that someone doesnt like. but we just have to move on and Enjoy the whole point of the show. to come out and show what you got. no matter if you win or loose its all about having a good time and just hanging out with fellow bass heads. The cash prize is just a bonus. lol
FLB.SPL.EVENTS Posted November 21, 2011 Report Posted November 21, 2011 CLASSES AS OF 11-12-11 *UPDATED* IN ALL CLASSES THE SYSTEM WILL BE MEASURED AT THE HEADREST. WITH OFFICIAL FLB HEADREST MOUNT. (choice of driver or passager headrest will be up to competitor) SEAT MUST BE IN UPRIGHT 90 DEGREE POSITION BUT CAN BE MOVED FORWARD OR BACK AS FAR AS FACTORY SEAT ALLOWED. ALL CLASSES WILL BE ABLE TO ROLL WINDOWS DOWN, LEAVE THEM CRACKED A LIL, OR SEAL THEM UP. (also sunroofs can be opened) DOORS WILL REMAIN CLOSED DURING RUN You will have 30 seconds to play a music track and recieve your peak db score Each Competitor will have 2 runs to get their best score. Duriing the event you may come up to the lanes and play your 30 sec run. once your score has been recorded you may wait to see if any other competitor breaks your score. if your score is beaten in your class you can use your second run to increase your score. Additional runs after your given 2 may be done for only $5 re-run charge. Additional runs are limited to 3 after your first orig 2. Additional runs must be completed before Eliminations begin. FOR EACH CLASS THE TOP 3 SCORING COMPETITORS WILL GO ON TO ELIMINATIONS TO PLACE 1-3 AND AWARD THE 1ST PLACE WINNER WITH CASH. For eliminations the highest score will wait while the other 2 competitors will compete against each other to see who is louder to go against the highest qualifying scoring competitor. 1st place will receive the pot of money from their class 2nd & 3rd place will receive printed certificates All competitors who compete at each FLB event will recieve FLBspl Dash Plaques for thier entry. Beginner Class: 2 classes (this class is great for anyone just starting out and wont have to worry about going against a system alot larger then theirs.) Beginner class: 1-2 subs or 3-4 subs SYSTEM WILL REMAIN BELOW WINDOW LINE OR IN TRUNK OF CAR. -All interior pannels must be in place -There will be a limit of 1500 rms in this class. -amps will not be clamped. -we will classify by the rating of the amp manufactures power lowest ohm load rating. MUST HAVE IN-LINE FUSE WITH LIMIT OF 100 amp Fuse. limit of 1 battery to be located in the stock position. no larger than group 31 battery Advanced Beginner: 1 class (this class for those who are still learning the ropes, but with a lil more power) 1-4 subs SYSTEM WILL REMAIN BELOW WINDOW LINE OR IN TRUNK OF CAR -All interior pannels must be in place -There will be a limit of 3000 rms in this class. -amps will not be clamped -we will classify by the rating of the amp manufactures power at their lowest ohm load rating. MUST HAVE IN-LINE FUSE WITH LIMIT OF 300 amp fuse. limit of 2 batteries total. 1 in stock location and 1 anywhere else inside the vehicle. Extreme Trunk Class: 1 class (a class for those who wanna see the most out of a trunk) ENTIRE SYSTEM WILL REMAIN IN TRUNK OF VEHICLE Subs, amp, batteries and enclosure must be within the vehicles trunk. -All interior pannels must be in place besides top seat cushion -Top Seat may fold down or be removed as long as everything stays inside the trunk line. -Deck Lid may be cut and if ported through the port may not extend more than 3" from the deck lid -no fuses required -no limit on power -no sub limit -no amp limit No Wall type Class: 2 classes (this is a class for all who do not have a full complete floor to ceiling wall) car / hatchback only class or truck, van, suv both classes will be as followed: -All interior pannels must be in place that are ABOVE 60% LINE -Custom door panels are allowed as long they are properly used -Center console may be customized as long as it retains useful -no limit on subs -There is no limit on power -no fuses required NO WALL HIEGHT IS BASED ON A 60% HEIGHT REQUIREMENT - for cars and hatchbacks the height will be measured from your trunk floor level to the height of your ceiling -suv's will be measured from the cargo area floor lever to the height your ceiling -trucks and vans will be measured from the main floor of the truck or van that the seats are bolted too, to the ceiling height. IN ANY CASE IT WILL ALSO BE BASED ON WINDOW LINE ALSO. IT WILL BE 60% OF HEIGHT OR WINDOW LINE, WHICH EVER IS GREATER. limited to 5 batteries total. 1 in stock location and 4 anywhere else inside the vehicle. *the reason for the limit is it can limit power. if you feel your setup needs more batteries to handle your power you will move to Heavy Hitters (see heavy hitters class for no limit on batteries) Wall type Class: 3 classes THIS CLASS IS FOR ALL ENCLOSURES AND SETUPS ABOVE THE WINDOW LINE BUT BEHIND THE B-PILLAR -All interior pannels must be in place (in front of the B-Pillar) -Custom door panels are allowed as long they are properly used -Center console may be customized as long as it retains useful -There is no limit on power -No fuses required -limited to 5 batteries total. 1 in stock location and 4 anywhere else inside the vehicle. *the reason for the limit is it can limit power. if you feel your setup needs more batteries to handle your power you will move to Heavy Hitters (see heavy hitters class for no limit on batteries) These classes will be divided by Cone Area. CLASS 1: UNDER 550" OF CONE AREA up to 7 -10" subwoofers up to 4 -12" subwoofers up to 3 -15" subwoofers up to 2 -18" subwoofers up to 1 -21" subwoofer CLASS 2: UNDER 1100" OF CONE AREA up to 14 -10" subwoofers up to 9 -12" subwoofers up to 6 -15" subwoofers up to 4 -18" subwoofers up to 3 -21" subwoofer CLASS 3: UNDER 1500" OF CONE AREA up to 19 -10" subwoofers up to 13 -12" subwoofers up to 8 -15" subwoofers up to 5 -18" subwoofers up to 4 -21" subwoofer ANY OTHER AMOUNT MORE THEN THIS WILL CLASS YOU IN HEAVY HITTERS. HEAVY HITTERS Class: 3 classes (These classes are for the big boys, classes for those with heavy hitting sytems) -no limit on subs -no limit on power -no limit on batteries Heavy Hitters 1: slight interior mods door panels may be molded and properly used. no other mods in front of the B-Pillar Heavy Hitters 2: roof can be braced with metal roof may be rhino lined roof can be sheathed with up to 1" thick of wood material on interior doors can be internally braced- to stop door cracks Heavy Hitters 3: ANYTHING GOES! (same as extreme classes) BASS LIMBO How LOW can you go??? This would be something extra at the event like port wars. 3 scores will be recorded then averaged to give your final score to see how loud you are at a range of frequencies. you will play 3 tones to see how good your setup plays them. 40hz, 30hz, and 20hz. there will be guys who get a great score at 20hz and not at 40hz and the other way around for other guys. so anyone could have the best average score. PLEASE FEEL FREE TO GIVE YOUR OPION ON ANY OF THESE CLASSES. THANKS
HelloMyNameIs Posted December 20, 2011 Report Posted December 20, 2011 Random question kind of relating to this topic Why are there no lighter wall classes? Because I have 4 15s and 2500rms And there are no lighter walled off classes (Im just above the window line; Therefore I was told I would be a wall - Yet to compete) I was just wondering why there arnt classes based like the non-wall with the rms/batt limits for walled vehicles? (Not trying to complain - just wondering because its discouraging to even attempt to compete knowing im going against guys with 15k rms and shit who have done this for years) ~This is added to the post you have just read: I appreciate everything you guys do, and I hope you understand how much it matters to have people like you helping me learn thanks so much ~Check my youtube for my music and my car audio: http://www.youtube.com/1ohmstable ~Rip dustin 7-11-09 Memorial build log: http://www.stevemead...memorial-build/
