Hey all my amps have a bass boost function, it's 400rms And my sub is 500w Rms I have 2 Amps and 2 subs. The amp has has boost 0-18db at 45hz should I use this feature or just set the gain correctly and leve it at zero cause I guess I should if I'm going to use it set it first cause it will affect the gain so set the boost then the gain ????
Or is it not advised to use it?
I Am Never Wrong, Just Often Mistaken......
Not really cause I don't know wether I should use it like I like the idea of if but I don't want it to affect the sq will it distort the signal cause it's trying to amp it too much
Maybe understanding bass boost might be good for you. Some good information in here
Just press me
