ClaytonPatrickMullins Posted October 17, 2011 Report Share Posted October 17, 2011 if you are reading this thanks. well i hav a incriminator audio death penalty 18 2010 series. and i waz playing my sub pretty hard and all of a sudden i look back and my dust cap is flying threw the air. wat is the best way 2 get it back on there or should i just get a new dust cap? thanks 4 any comments. Quote Link to comment Share on other sites More sharing options...
Azagtoth502 Posted October 17, 2011 Report Share Posted October 17, 2011 If the cap isn't broken just use some epoxy to re-attach it. Quote pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls Link to comment Share on other sites More sharing options...
KillaCam Posted October 17, 2011 Report Share Posted October 17, 2011 Use some ca glue, and set something on the dust cap for weight while it dries. Quote And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log Link to comment Share on other sites More sharing options...
raolito1980 Posted October 17, 2011 Report Share Posted October 17, 2011 I glue my dstcap and let sit for a couple days. Quote 2012 GMC SIerra CC System Build Headunit--Stock Sub Amp--DC 2.0k Subs--2-SA8v2's Enclosure--Need one made!! Highs Amp--Sundown SAX-100.4 Front Highs--Rockford Fosgate T2652-S Rear--Sundown Neo Pro 6.5 XS Power D2400--XS D3400 No Big Three yet! http://www.youtube.c...ser/raolito1980 Link to comment Share on other sites More sharing options...
ClaytonPatrickMullins Posted October 17, 2011 Author Report Share Posted October 17, 2011 would i have 2 remove the old glue from the dust cap and then apply new glue? Quote Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted October 17, 2011 Report Share Posted October 17, 2011 yea, remove the glue, you can usually pull it off by hand and it will come off in pieces. But a decent amount of rubber or ca glue and glue it back on. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
ClaytonPatrickMullins Posted October 17, 2011 Author Report Share Posted October 17, 2011 yea, remove the glue, you can usually pull it off by hand and it will come off in pieces. But a decent amount of rubber or ca glue and glue it back on. thanks. and yeam imma put plenty of that shit on there! Quote Link to comment Share on other sites More sharing options...
traxxas101 Posted October 17, 2011 Report Share Posted October 17, 2011 yea, remove the glue, you can usually pull it off by hand and it will come off in pieces. But a decent amount of rubber or ca glue and glue it back on. thanks. and yeam imma put plenty of that shit on there! i found that taking a cup and turning it over on top of the dust cap and adding a weight or something heavy works while its drying! Quote Link to comment Share on other sites More sharing options...
Blackedout Posted October 17, 2011 Report Share Posted October 17, 2011 Get some rubber based ca glue and some activator. Clean up the dustcap and scuff it up a little. I use a 6-8" speaker to add weight to the dustcap. Quote Trunk Build Log Link to comment Share on other sites More sharing options...
KillaCam Posted October 18, 2011 Report Share Posted October 18, 2011 i found that taking a cup and turning it over on top of the dust cap and adding a weight or something heavy works while its drying! Thats a damn good tip Quote And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log Link to comment Share on other sites More sharing options...
