csill420 Posted October 19, 2011 Report Share Posted October 19, 2011 Wats up everyone! Im not sure if its possible but i heard u can replace the stock battery up front in an 02 chevy tahoe with the kinetic hc 2400. I wanna do the transplant but i dont know if it can be done. If it could or if thers another kinetic you can use to replace it please lemme know. Quote Fuck warning points. Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted October 19, 2011 Report Share Posted October 19, 2011 try measuring the stock battery, and then compare that to the aftermarket battery sizes. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
csill420 Posted October 19, 2011 Author Report Share Posted October 19, 2011 try measuring the stock battery, and then compare that to the aftermarket battery sizes. What about the cca's that doesnt matter? Quote Fuck warning points. Link to comment Share on other sites More sharing options...
bass_stalker Posted October 19, 2011 Report Share Posted October 19, 2011 if im right you can fit an xspower d3400. it would be better than that kinetic most likely Quote JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow. Link to comment Share on other sites More sharing options...
Team Bassick - Kimo Posted October 19, 2011 Report Share Posted October 19, 2011 The 2400 will not just drop in if thats what your asking. Will it fit, SURE. might need to remove somethings and make some brackets. Quote KIMO @teambassick http://www.teambassick.com Link to comment Share on other sites More sharing options...
csill420 Posted October 19, 2011 Author Report Share Posted October 19, 2011 The 2400 will not just drop in if thats what your asking. Will it fit, SURE. might need to remove somethings and make some brackets. I dont mind chopping. But is my truk still gunna start and function all the stok electrical ok with it in as a replacement? Quote Fuck warning points. Link to comment Share on other sites More sharing options...
LoudBimmer Posted October 19, 2011 Report Share Posted October 19, 2011 The 2400 will not just drop in if thats what your asking. Will it fit, SURE. might need to remove somethings and make some brackets. I dont mind chopping. But is my truk still gunna start and function all the stok electrical ok with it in as a replacement? Why wouldn't it? Replacing stock battery with aftermarket one is just like replacing small bottle of water with bigger one. Same thing, exept you can now drink much more Quote Link to comment Share on other sites More sharing options...
flashlight_65 Posted October 19, 2011 Report Share Posted October 19, 2011 An 1800 will drop in but a 2400 will be a bit of work. Make a template using 1/4" mdf see how you can make it fit instead lugging that big ass battery. (that's what I plan on doing for my 'hoe and shifting the 1800 in the second tray) Good luck Quote My builds: my caddy my 'hoe friends impala Link to comment Share on other sites More sharing options...
csill420 Posted October 20, 2011 Author Report Share Posted October 20, 2011 The 2400 will not just drop in if thats what your asking. Will it fit, SURE. might need to remove somethings and make some brackets. I dont mind chopping. But is my truk still gunna start and function all the stok electrical ok with it in as a replacement? Why wouldn't it? Replacing stock battery with aftermarket one is just like replacing small bottle of water with bigger one. Same thing, exept you can now drink much more Haha thanks man made it easy for me Quote Fuck warning points. Link to comment Share on other sites More sharing options...
csill420 Posted October 20, 2011 Author Report Share Posted October 20, 2011 An 1800 will drop in but a 2400 will be a bit of work. Make a template using 1/4" mdf see how you can make it fit instead lugging that big ass battery. (that's what I plan on doing for my 'hoe and shifting the 1800 in the second tray) Good luck Thanks man! Quote Fuck warning points. Link to comment Share on other sites More sharing options...
