Box type that sounds the best when you're close?
Hey guys. I'm planning on putting a 10" in my dorm room soon. I currently have a KEF 8" woofer that's in a 1ft^3 box with a passive radiator on the opposing side of the driver. to help it hit lower and harder, it's stuffed full of (half) subwoofer box stuffing and (half) t-shirts and sweatpants. I want to put my 10" driver right under my desk, but as i've experienced with my 8", having the woofer right under your feet doesn't make for the best sound experience. I'm planning on doing a t-line for the 10", but would a sub-up port-up box sound better when I'm right next to it? thanks guys
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
If you have the room.I've built a couple boxes for our home theater sub. Its a DC lvl 2 12 and is ran off a 300 watt plate amp hooked up to a sony 5.1 surround sound reciever utilizing all the Sony speakers cause they are pretty high end. At first I did a plain sealed box decent output just not as loud as I wanted then again you gotta realize my living room is prolly the size of 6 of your dorm rooms put together in a different.configuration of course. Then I.did a simple low tuned ported box and it sounded great on movies but when I.put on music it kinda lacked being tuned so.low. now we have a 73" TV cady corner in one.of the corners only way it will all fit and we can.all see it (hell we had to take our.pitcher window out to get part of our sectional in and we.have double front doors) so that kinda gives you an idea of the size. All of these boxes were behind the TV.back against the wall with the plate amp. So after not.liking the low tuned ported box on music I said fuck it and.built a low tuned t line and that's the winner and that's what you should build. It sound.great on hip hop or higher tuned music and.on epic bass drops on movies lots of stuff falls off the walls and.the bass.is turned down as.far as it can go on the reciever and.gain.halfway up and.lpf at 100 on the plate amp, keep in.mind this is with dc's entry lvl sub too. I know t lines take up more space but if you can make it work do.it. you won't be sorry one.bit.and you can even.build it a.certain way where it.could be a table by you're bed too and tripple up the top so your stuff isn't falling off. I know its a long read but I hope I helped somehow.
I apologize for all the extra. . . . . . . . Periods the way my phone is the . Is close to the space bar and my fingers arnt small. Good luck and post results :)
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
hahaha okay sweet thanks. my dorm room is probably 38' x 50'. t-line sounds good
I'm also thinking about doing a sub-out port-down box. would this be best, having the sub pointing out towards the middle of the room, or should i go sub-down port-down? the floor is carpet on top of cement, and the carpet is pretty low (probably 1/4-1/2 inch thick)
