SilveradoGoesBang Posted October 24, 2011 Report Posted October 24, 2011 This is not my picture and the persons who it is unknown and i have a truck similar and would like to do this so i can make my floor of my sub box and maximize airspace i have the same back sears basiclly. My Questions 1) What do i need to do this? 2) How do i do this? 3) And if i do this can i screw through it into mdf for the sides or will it split the fiberglass? Thanks for any and all help! "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
roscoe1129 Posted October 24, 2011 Report Posted October 24, 2011 Tape off uour floor with masking tape. Spray adhesive to it and lay tin foil over it. Get some fiberglass resin and matt and wet the floor with the resin then lay out some chop mat peices TORN off of the bulk of the matt not cut (the torn edges lay across each other and create strength) and take a paintbrush wet with resin and tap it into the matt. Wetting it thru but not so it puddles. Do this till your matt is about a 1/4" thick. Then you can take your wood and put your bottomless box on this and secure it with more matt. Look at the fiberglass section here and you will find alot of tutorials on fiberglassing. Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
tctdh11 Posted October 24, 2011 Report Posted October 24, 2011 Best way I can think to do this would be to lay plastic down or tape the entire area then lay mat and resin it. let it dry then pull the plastic or tape free and you have it. Since you're planning on making a box this way I would do the tops and sides in mdf or birch and make sure to make the bottom as thick as possible. ^^^ ninja'd me lol TEAM DC www.dcsoundlab.com 2003 Tiburon GT V6 6 Speed Ported Clam 6 12" DC Audio XL M2's 2 American Bass 1100.1 1 American Bass 350.4 3 D3100, 1 D975, 3 D925 Second Skin Damp Pro and Spectrum. About 75% done 153.6 Sealed on dash at 34hz My OLD Build Log New Build Log.. DC XL M2 4th Order in my Tiburon
SilveradoGoesBang Posted October 24, 2011 Author Report Posted October 24, 2011 Tape off uour floor with masking tape. Spray adhesive to it and lay tin foil over it. Get some fiberglass resin and matt and wet the floor with the resin then lay out some chop mat peices TORN off of the bulk of the matt not cut (the torn edges lay across each other and create strength) and take a paintbrush wet with resin and tap it into the matt. Wetting it thru but not so it puddles. Do this till your matt is about a 1/4" thick. Then you can take your wood and put your bottomless box on this and secure it with more matt. Look at the fiberglass section here and you will find alot of tutorials on fiberglassing. kk So spray glue the foil to the tape then just do one layer at a time till think as i need and dont screw to the box firberglass it into the box? Also do i need to f26 it before i glass the wood to the floor?(let each layer dry before doing another one?) Whats the exact kind of resin and matt i need? "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
SilveradoGoesBang Posted October 24, 2011 Author Report Posted October 24, 2011 Tape off uour floor with masking tape. Spray adhesive to it and lay tin foil over it. Get some fiberglass resin and matt and wet the floor with the resin then lay out some chop mat peices TORN off of the bulk of the matt not cut (the torn edges lay across each other and create strength) and take a paintbrush wet with resin and tap it into the matt. Wetting it thru but not so it puddles. Do this till your matt is about a 1/4" thick. Then you can take your wood and put your bottomless box on this and secure it with more matt. Look at the fiberglass section here and you will find alot of tutorials on fiberglassing. Yes i was planning to do the tops and sides as mdf and let each layer dry before i do another one right? "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
roscoe1129 Posted October 24, 2011 Report Posted October 24, 2011 http://www.stevemeadedesigns.com/board/topic/30154-tubbing-out-a-spare-tire-well/ That is a tutorial to basically the same thing but in a trunk. Should have all the info you need Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
SilveradoGoesBang Posted October 24, 2011 Author Report Posted October 24, 2011 http://www.stevemeadedesigns.com/board/topic/30154-tubbing-out-a-spare-tire-well/ That is a tutorial to basically the same thing but in a trunk. Should have all the info you need Awesome tyvm "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
roscoe1129 Posted October 24, 2011 Report Posted October 24, 2011 http://www.stevemeadedesigns.com/board/topic/30154-tubbing-out-a-spare-tire-well/ That is a tutorial to basically the same thing but in a trunk. Should have all the info you need Awesome tyvm N.P. Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
larrys95civic Posted October 24, 2011 Report Posted October 24, 2011 I'm currently working on a dodge and putting 2 sa-8's under the back seat, I don't have any step by step pics but I have a few progress pics be happy to answer any questions about how I do boxes like this just toss me a pm Team Superior SPL Former Installer at Driven Sound & Security http://www.drivenss.com All kinds of forsale threads http://www.stevemeadedesigns.com/board/topic/164247-amps-subs-and-misc/#entry2383262 http://www.stevemeadedesigns.com/board/topic/164430-polk-audio-sda6000-sound-bar/#entry2386634 http://www.stevemeadedesigns.com/board/topic/164279-3-michael-kors-watches/#entry2383983 http://www.stevemeadedesigns.com/board/topic/164549-more-items-from-storage/ http://www.stevemeadedesigns.com/board/topic/166967-dd-9518s-amps-kenwood-custom-explorer-dash/ If someone is feeling generous I'd love an original sig LOL
