DC Sound Lab
Level fives or XL??
Op you need power to make power... 1 alt and big 3 isn't goin to do it. 2xls and 1- 7.5
If you have to point out to him that his electrical is quite insufficient, don't you think a DC 7.5k is a little much for him to try to put on a pair of XL's? :pardon:
But really, less subs, less amplifiers, more electrical.
Sorry didnt finish.. op do as many batterys as you can at least 3 - 3100s a good 270a alternator and multiple runs of 0g. I think 1 amp is easier to wire and 2 5ks is too much so 1 7.5 is perfect. I run 3k daily each to my xls off of 2 amps but I'm switching to 1 to see if I gain
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
I never said I was getting a 7.5? I am getting one AQ 3500
Edited by Sid420
One 3500 should be fine for you then.. :-) good luck
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Im looking into walling my 4 door full size GMC sierra and with the correct cubes i need i cannot fit 4 18s in there (they will need somewhere near 24 cubes after displacements. when you get a port big enough to do at least 13 inches per cube it wont happen in that car. even when you run that power and shrink the box it wont work. there is not enough space to get all the subs forward and the port being big enough. then that big of a port will be displacing at least 6-7 cubes from the box then each sub is .26 so atleast 8 cubes displacement excluding bracing you will need. also itll have to be minimum 3 layers think.
I just dont see it happening honestly theres just no room.
2 18s yes 4 not likely
Contact us for the best quality cables and accessories with the fastest shipping in the industry
EMAIL: [email protected]<script data-cfhash='f9e31' type="text/javascript"> /* */</script>
LIKE US ON FB: https://www.facebook.com/SkyHighCarAudio
ADD ME ON FB: https://www.facebook.com/jon.rabe.1
MONSTER SKY HIGH/DC GMC: http://www.stevemeadedesigns.com/board/topic/127057-sky-high-monster-gmc-walk-through-12-lvl-5-15s-6-9ks-trim-panels-and-wiring-p-90/
HAHAHAHAHAHAH this is to funny it went from 4 to 8 2200 to 4 3500 to 1 3500
the car still wont last a year lmao
shit i dont give it 3 months if the kid even does the shit hes talking about
excatly what i thought when i saw this :lol:
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
why not 4 lvl 5s on 4 aq 3500s? that would work out nicely..
and that saves a ton of $... compared to 8 amps..
you dont have to run stupid power to the subs to get loud, i ran 1 7k to 3 lvl 5s and
was pulling 55s on music at the head....
4 3500 isn't that a bit much why not just four 2200?
4 x 3500 = 14000
8 x 2200 = 17600
Why not 2 AQ 20 = 16000 golden middle
"in the abundance of water, the fool is thirsty" Bob Marley
  • Who's Online   0 Members, 0 Anonymous, 1928 Guests (See full list)
