OrionStang Posted April 24, 2013 Report Share Posted April 24, 2013 Common port walls should be "1". That pic is tiny as hell BTW. 1 Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
lolitskasey Posted April 24, 2013 Author Report Share Posted April 24, 2013 (edited) Yeah I saw that I will re size it when I get back to my desk on my lunch break Edit: so since I will have two bends cause I want my port to be in the middle of the box would I want to cut the total length of the port in half? Example, the port length is 31 would I cut that in half to make two bends? Sorry if that didn't make any since its hard to explain. On my lunch break I will make a visual. Edited April 24, 2013 by lolitskasey Quote Link to comment Share on other sites More sharing options...
OrionStang Posted April 24, 2013 Report Share Posted April 24, 2013 Visual would be good. I was assuming the port was along the bottom facing back. If the port is vertical in the center, leave the common walls at "2". Ill do a quick sketch of how your port should look. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
OrionStang Posted April 24, 2013 Report Share Posted April 24, 2013 View from the top. You don't cut the length in half, but the width of the port is halved. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
lolitskasey Posted April 24, 2013 Author Report Share Posted April 24, 2013 Thats was i was trying to verify. so both bends would be, 18" long and do the 90 9 7/8? Quote Link to comment Share on other sites More sharing options...
OrionStang Posted April 24, 2013 Report Share Posted April 24, 2013 Yes. Unless somebody see's I'm doing something wrong Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
lolitskasey Posted April 24, 2013 Author Report Share Posted April 24, 2013 (edited) EDIT: Tweaked my box design a little bit and made up a little visual how does everything look? Edited April 29, 2013 by lolitskasey Quote Link to comment Share on other sites More sharing options...
lolitskasey Posted May 9, 2013 Author Report Share Posted May 9, 2013 Some updates, it was a amazing day outside for once. I got all my power wire cut and soldered to length. I also bought a new AGM bat for under my hood. Quote Link to comment Share on other sites More sharing options...
lolitskasey Posted May 11, 2013 Author Report Share Posted May 11, 2013 Got some work done yesterday ran my power, going to run my grounds today and start on my box. Quote Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 11, 2013 Report Share Posted May 11, 2013 That's a healthy amount of wire Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
