adreano17 Posted October 27, 2011 Report Posted October 27, 2011 I have a 96 ES300 w/ stock 80A, and I'm going to get a rebuilt 170A alt, and currently running a Deka 9a34 under the hood. Going to be doing the big3 as well, with all 1/0 wire, +running to the back Build: 2 Kicker L7s 12s running from, Brutus 1700.1D CEA-comp 800a4 running only 320 for components @ 4 channel _________________________ I think I will be good, I just want to get some opinions on it. Quote Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
adreano17 Posted October 28, 2011 Author Report Posted October 28, 2011 bump Quote Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
miniSPLlancer Posted October 28, 2011 Report Posted October 28, 2011 A couple batteries wouldn't hurt either Quote 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
cjvue Posted October 28, 2011 Report Posted October 28, 2011 You'll be fine if you're not playing full blast long. I would get a volt meter along with those equipment and monitor voltage drop. If you're dropping too low, a decent second battery should be help. Quote My Build Log- T E A M S U N D O W N A U D I O - 2013 DbDrag WF SS1-2 - 5th Place 154.6db 2013 MECA Mod3 CA State Final Champ 153.4db Powered by: Sundown Audio
cjN Posted October 28, 2011 Report Posted October 28, 2011 I'd add another battery in the back. Quote 2x sundown audio sa 12's Crescendo BC2000 kinetik 1800, 1400. Rockford punch 5,25 component set MB QUART ONYX 4.80 Mechman 270a alt
poorfish88 Posted October 28, 2011 Report Posted October 28, 2011 I have run similar systems with 80a alt, and had bad voltage drop into the 11s.. Nothing shut down or anything, but I needed a output alt for sure. Plus I'd use an extra batt in back, and if you got the money I'd go AGM front and back. Quote
adreano17 Posted October 28, 2011 Author Report Posted October 28, 2011 (edited) I have run similar systems with 80a alt, and had bad voltage drop into the 11s.. Nothing shut down or anything, but I needed a output alt for sure. Plus I'd use an extra batt in back, and if you got the money I'd go AGM front and back. Got AMG in front. Edited October 28, 2011 by adreano17 Quote Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
Mario928 Posted October 28, 2011 Report Posted October 28, 2011 you should be alright. if you see voltage drop just add another battery and you will be fine Quote Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill
adreano17 Posted October 28, 2011 Author Report Posted October 28, 2011 You'll be fine if you're not playing full blast long. I would get a volt meter along with those equipment and monitor voltage drop. If you're dropping too low, a decent second battery should be help. Luckily my radar detector has a voltmeter on it Quote Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
ChevyBoy95 Posted October 28, 2011 Report Posted October 28, 2011 You'll be fine if you're not playing full blast long. I would get a volt meter along with those equipment and monitor voltage drop. If you're dropping too low, a decent second battery should be help. Luckily my radar detector has a voltmeter on it you want voltage of the amplifier, not the stock location battery. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
