barney91 Posted November 3, 2011 Report Share Posted November 3, 2011 I have a 99 yukon with 214,xxx miles just recently it started running bad.on Friday it was running bad so I stopped at a friends and after it wouldn't start, I noticed that my fuel gauge read past full. So I got towed to my house and when I got home it started right up but it wouldn't go pass 3000rpm even with me flooring it. When it would hit 3000rpm it would bogg out and drop to 2000rpm then right back to 3000rpm and then back to 2000rpm and so on, at the same time it would bogg out my fuel gauge would shoot to full then drop back to 1/4 tank So I thought I was having a bad fuel pump so first I swapped the fuel relay and the fuel filter and the problem was still their. All this was on friday, the next day it would only run for a few seconds and shut of so I went ahead and swaped the fuel pump with a delphi fuel pump Well today I finished everything and its still only running for a few seconds before it shuts off the only thing I can think of is the fuel pressure regulator What else could it be? Any help is greatly appreciated P.S. sorry for the long post just really despret for help and also I'm on mobile so sorry for any misspelled words Quote Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1 Link to comment Share on other sites More sharing options...
teardrop Posted November 3, 2011 Report Share Posted November 3, 2011 look here for some ideas http://www.stevemeadedesigns.com/board/topic/120006-free-ondemand/ and have you changed anything before it started acting crazy Quote Link to comment Share on other sites More sharing options...
SkylarDunn Posted November 3, 2011 Report Share Posted November 3, 2011 (edited) First thing i would do, have a code reader put on the Ecu. I'd guess either your fuel pump wiring circut has a problem, your injectors are bad, you need an o2 sensor (just put one in my grandfather suburban) or your ECU is reading something wrong and need to be re-flashed. Edit: also, you could buy a can of MAF cleaner and clean the mass air flow sensor. It might not be the problem, but at that many miles, it would at least need to be cleaned, if not replaced. Edited November 3, 2011 by SkylarDunn Quote Getting bass into the cabin of a W124 mercedes is impossible. Current setup: Temp 1999 panasonic HU rockford 300.2 for fronts rockford 200.2 for rears rockford 400.1 for sub Leaning towards a 8" in an exponential horn DAMN YOU GERMANS AND YOUR 5" SPEAKERS! Link to comment Share on other sites More sharing options...
theTank77 Posted November 3, 2011 Report Share Posted November 3, 2011 when was the last time you gave it a tuneup? when was the last time you put fuel system cleaner in it? go get a bottle of Seafoam and dump it in your tank then go fill up. let the truck sit overnight to dissolve all the shit in your fuel system start up your truck in the morning and let it run for a lil while. see if it runs better. Quote my build log Link to comment Share on other sites More sharing options...
teardrop Posted November 3, 2011 Report Share Posted November 3, 2011 is your check engine light on if not a code reader want help also do you have a fuel pressure gauge? and try unpluging the mass air flow metter and see how it runs when you unplug a elctronic seanser or any thing your ecu goes into a limp mode so you can get it to a shop but it will run beter with a bad part unpluged than reading a bad part Quote Link to comment Share on other sites More sharing options...
SkylarDunn Posted November 3, 2011 Report Share Posted November 3, 2011 (edited) when was the last time you gave it a tuneup? when was the last time you put fuel system cleaner in it? go get a bottle of Seafoam and dump it in your tank then go fill up. let the truck sit overnight to dissolve all the shit in your fuel system start up your truck in the morning and let it run for a lil while. see if it runs better. Fuel system cleaner is great, if you want your seals to fall apart in the next 500 miles. Also, dont EVER put seafoam in your gas unless its the rare seafoam made specifically to be put in gas. The way you should use seafoam would be to add it to your oil, let the engine idle for 10 min, then drain the oil, and replace it. I really hope you dont put seafoam in your gas. Edited November 3, 2011 by SkylarDunn Quote Getting bass into the cabin of a W124 mercedes is impossible. Current setup: Temp 1999 panasonic HU rockford 300.2 for fronts rockford 200.2 for rears rockford 400.1 for sub Leaning towards a 8" in an exponential horn DAMN YOU GERMANS AND YOUR 5" SPEAKERS! Link to comment Share on other sites More sharing options...
teardrop Posted November 3, 2011 Report Share Posted November 3, 2011 when was the last time you gave it a tuneup? when was the last time you put fuel system cleaner in it? go get a bottle of Seafoam and dump it in your tank then go fill up. let the truck sit overnight to dissolve all the shit in your fuel system start up your truck in the morning and let it run for a lil while. see if it runs better. Fuel system cleaner is great, if you want your seals to fall apart in the next 500 miles. Also, dont EVER put seafoam in your gas unless its the rare seafoam made specifically to be put in gas. The way you should use seafoam would be to add it to your oil, let the engine idle for 10 min, then drain the oil, and replace it. I really hope you dont put seafoam in your gas. yea i hate seafoam and fuel system cleaners they are junk Quote Link to comment Share on other sites More sharing options...
barney91 Posted November 3, 2011 Author Report Share Posted November 3, 2011 Thanks for the reply guys Last tune up was august and I've scanned it and there's no codes so no check engine light And id do the fuel cleaner but it only runs for like 5 seconds and shuts off by its self so I don't think it would do much Also I did check the fuel presure and its on 60 as it starts once its on it stays at 55 Quote Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1 Link to comment Share on other sites More sharing options...
teardrop Posted November 3, 2011 Report Share Posted November 3, 2011 (edited) fuel pressure is good look at the mass and tps those should throw a code but not allays and unplug a fuel injector one at a time and see if it makes a deference if it don't make a deference on one you pull its bad or clogged and do the same on plug wires Edited November 3, 2011 by teardrop Quote Link to comment Share on other sites More sharing options...
barney91 Posted November 3, 2011 Author Report Share Posted November 3, 2011 Well if the mass was going bad wouldn't there be a code And couldn't a bad fuel pressure regulator cause the same problem? Quote Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1 Link to comment Share on other sites More sharing options...
