OK, so I've had this problem forever and can't seem to crack it or find the source of it. This is what happens, i can hear my alternator whine through my speakers...gets higher pitched as i rev. I can put the volume to 0 and it will play just as loud. I also hear some of my electronics such as when i'm closing my sunroof, or putting on my blinkers through my speakers too. Here are all the things I've tried, and if you have any suggestions at all or any way of fixing this please speak cause i'm all out of idea's.
Tried...
Ground Loop Isolater
Noise Filters
Different Head Unit
Power Wire's On one side, Speaker wire and RCA's on other side
Checked to see if Headunit and Amps were grounded With a Meter (They Are)
If you have any questons on the equipment i have, Its all listed in my sig. Thanks
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
Have you tried finding a new ground? If not then where is it currently grounded? Also have you tried switching out the RCA's?
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
Its a common problem in GM vehicles. if you are running non restrictor plugs and/or wires it could be your problem.
Whats That?
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
Yes, I've switched grounds. My amps negatives are connected to my reae battery and my rear battery is grounded on the frame. No i havn't tried different Rca's yet, I'll try that tommorow
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
you have a pioneer. You have a blown pico fuse. thats the issue.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
i"ve switched out the radio with a brand new one.. same thing happens
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
then you need to recheck all the connections to your HU, try pulling it out run a good + and - lead to the HU and see if the issue keeps happening. Use deductive reasoning
and pioneers will do that out of the box sometimes...
Posted (edited)
Ground your HU all the back to the same grounding point as your amps with 10g wire. Pull all extraneous connetions from HU, like the antenna jack, those could be grounding out also. Make sure you HU metal case isn't grounding out. Make sure your amps metal casings aren't grounding out. Run new RCAs directly from HU to amps over your seats. My god there are a million things to try... Google and start making a list... within an hour you should have 100 items on that list to try. Every time I finish an install I have to fix at least 2 causes of alt whine and they are never the same 2 causes.
Edited by Merzbow
  • Who's Online   0 Members, 0 Anonymous, 1452 Guests (See full list)
