Can someone help me out with a vin check.PLEASE.Thanks
HEAD UNIT JENSEN VM9312
4 12" KICKER COMPS
4 PUNCH 150 AMPS "0NE ON EACH SUB"
2 ALPINE 3522 ON MIDS AND HIGHS
MLA MOD
BIG 3
OPTIMA D31T BATTERY UP FRONT, ANOTHER IN BACK
2 KINETIK BATTERIES IN BACK ALSO"ONE 800,ONE 1200"
DUAL ALTERNATORS "ONE 200 AMP" OTHER MECHMAN 270 LARGE CASE
what do you wanna know about it?
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Anything i can find out about it.I'm trying to find out where it might be.
4 12" KICKER COMPS
MLA MOD
BIG 3
couple of different places it can be, usually it would be on the dashboard on the drivers side. or it can be in the drivers door, or my jeep even has it stamped under the hood. and there are also vin codes on the engine, transmission, and frame
Sorry for the confusion guys.I already have the vin number.What i'm asking can someone run it for me?
4 12" KICKER COMPS
MLA MOD
BIG 3
oh, i'm not really sure if you could do anything like that, though i think the dmv can check to see if it has been flooded or salvaged or anything like that
Edited by bass_stalker
Thanks
4 12" KICKER COMPS
MLA MOD
BIG 3
Also don't bother with Carfax unless the car is new and still under a warranty, even then its iffy. Carfax is optional, dealers will usually update the Carfax but if the car was taken to a local mechanic unless the person updates the carfax themselves it won't be listed. Just something to think about, only good for seeing how many owners the car has had.
Edited by wonderbreadSTS
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
Even if you did look it up. Its still useless. I would inspect every aspect in person. Do a check on everything. And try for a few days. And last I checked, It was illegal to run a Vin check? I tried when i was searching for the previous owner and a abandoned car left for repair. And got no where.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
