I have noticed that threaded rods are used for bracing.Is that better than using 2x2's or baffles.I really like your box.Looks like it can handle some power with no flex.
i've never personally used threaded rod, but from what i hear, it's a very good alternative for 2x2's. they don't displace much air and don't interrupt airflow as much.
Ok thank you.I really think of the airflow being interrupted inside of a box.How much dose that affect the performance.
i can't really get specific here, as i haven't compared the two. i'd think to your ears it may or may not be noticeable, but to the meter it would probably make a good bit of difference.
More box builds
I'm with captain stupid.
i think you should put 2 45's on the corners opposite to the port (so 45-sub-port-sub-45)
So i have another idea i would like. How is this specs and design for this setup.
Also could someone help me with the port measurements on the length? Just wondering how i would get the length i need with the port bending this way. I am extremely thankful for support or advice.
thats all i can think of unless someone pops in with a good design back round
edit: changed letter color green was sorta hard to see on my screen
Are you suggesting 45's all the way across as i did the bottom or just maybe 45's as a piece that are about 1" or 2" thick? If i read the post correctly you are suggesting 45's as a piece. I will add the 45's at the top as suggested just not sure how you mean.
Yes i have noticed the round rods as bracing as well. I was just looking at purplehaze's box and it looked great. I also figured i would use less displacement with the rods
srry i was a bit unclear on wording basically like you have it on the bottom corners just on the top as well just don't do it on where the port is seems like it kinda cuts off air that could be going through the port
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
the 2 45's across the bottom like you have in your picture should be just fine. i wouldn't put 45's at the top of the box, because you're not going to see any gains from that. just gonna displace more air.
and in response to an earlier post, give the port some breathing room. 1" from the hatch probably isn't a great idea.
More box builds
Yeah as i figured, so i will end up trying out the second box idea. It will be port and sub up. So my next question is how would i do this port bend? I am very unclear of the bends in the port and dont want to be doing the wrong measurements. If my port length is 26" on the torres how would i account for that with how i have the way this port is?
Ok thanks,even though I forgot didn't in my last post.Where can I find info on this subject to see if it will make a difference in my box buil.
Is there any performance reasons for port and sub up. Or is it just cosmetic purpose?Oh thank you again for getting my pic up.I tried to get my screenshot up but it did the same thing. How important is the 45's thing in the boxes I just haven't really got it yet.
