CanNotT0uchThis Posted November 6, 2011 Report Posted November 6, 2011 Well I have recently installed subwoofers in my car and ever since then I hear a buzzing/humming noise from my front/rear speakers. I already tries to look up a solution on google it said make sure your power cable is not with your RCA cables and there on different sides of the car. I also figured out that it doesn't make the noise if the cars electrical is just on it makes it when the car is actually started. And if I unplug the RCA cables from the amp it also stops humming... Oh and I also have a 2002 Dodge neon of that has anything to do with it.. Thanks, Austin
skittlesRgood Posted November 6, 2011 Report Posted November 6, 2011 then you have interference coming through your RCAs. they might run by some other powered device in the car. try running them a different way or get shielded RCAs. also, interference from the sub's RCAs can affect the mid/high's RCAs. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
DudeWith4x4 Posted November 6, 2011 Report Posted November 6, 2011 I had this same trouble through my doorspeakers once I installed my Double Din head unit and it annoyed the shit out of me. I put the aluminun tape around all my RCAs where they ran through the dash and where they crossed a power wire. Check all your grounds aswell. Make sure where ever they are mounted they have direct contact with metal.. Like sand or take a wire brush to the areas where they make contact. Hope you figure it out man. -Ross Project Layla Truck: 99' F-150 Gathering things for my next build. SoloX18 build: http://www.stevemead..._1#entry1576460 RE T-line build: http://www.stevemead...-between-build/
pimpnFosgates Posted November 6, 2011 Report Posted November 6, 2011 incorrect sir, its a ground loop, if you can run your grounds from amps n deck straight to batt itll stop. if you dont wanna do that, try a ground loop isolator on the rcas closest to amp for your speakers. you have a ground loop Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
CanNotT0uchThis Posted November 6, 2011 Author Report Posted November 6, 2011 incorrect sir, its a ground loop, if you can run your grounds from amps n deck straight to batt itll stop. if you dont wanna do that, try a ground loop isolator on the rcas closest to amp for your speakers. you have a ground loop My front and rear speakers aren't connected to a amp. just my sub woofer is
skittlesRgood Posted November 7, 2011 Report Posted November 7, 2011 incorrect sir, its a ground loop, if you can run your grounds from amps n deck straight to batt itll stop. if you dont wanna do that, try a ground loop isolator on the rcas closest to amp for your speakers. you have a ground loop a ground loop should sound more like a whine/ringing rather than a buzzing/hum. incorrect sir, its a ground loop, if you can run your grounds from amps n deck straight to batt itll stop. if you dont wanna do that, try a ground loop isolator on the rcas closest to amp for your speakers. you have a ground loop My front and rear speakers aren't connected to a amp. just my sub woofer is it doesnt matter that they are not on an amp. tell us where and how you have the sub amp grounded. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
CanNotT0uchThis Posted November 8, 2011 Author Report Posted November 8, 2011 incorrect sir, its a ground loop, if you can run your grounds from amps n deck straight to batt itll stop. if you dont wanna do that, try a ground loop isolator on the rcas closest to amp for your speakers. you have a ground loop a ground loop should sound more like a whine/ringing rather than a buzzing/hum. incorrect sir, its a ground loop, if you can run your grounds from amps n deck straight to batt itll stop. if you dont wanna do that, try a ground loop isolator on the rcas closest to amp for your speakers. you have a ground loop My front and rear speakers aren't connected to a amp. just my sub woofer is it doesnt matter that they are not on an amp. tell us where and how you have the sub amp grounded. I grounded it with my tail light in the trunk. The paint wasn't scratched off so i sanded it all off where the tail light and my sub are grounded to.
