michigancapri92 Posted November 7, 2011 Report Posted November 7, 2011 does the size of the remote wire make a difference ? and if im running two amps should i have remote from HU go to a relay and then to the amps ? Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
KenC210 Posted November 7, 2011 Report Posted November 7, 2011 does the size of the remote wire make a difference ? and if im running two amps should i have remote from HU go to a relay and then to the amps ? don't think it does i have 18g off 3 amps and i do use a relay edit: i also bought the relay so i could use it with fans and leds Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Paul M Posted November 7, 2011 Report Posted November 7, 2011 As far as I know, size doesn't matter. And I myself have never done it, but my friend does, for two remote wires he just connects them then solder/tapes em.
Neo_frog Posted November 7, 2011 Report Posted November 7, 2011 It only matters if there's an extremely long run with a lot of resistance (butt splicing, relays, etc.). Amp relays and over all power usage will perform better with the remote getting sufficient voltage. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
