Quick little 65 Mustang now supercharged??? 4 AB 6.5 subs
Lol
No it's a ford they circled the problem I know where it is....
She will be worth of a drive very soon
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Lol
Lol bet can't haul four batcapp 4000 on stock suspension.
A 99-04 Cobra IRS won't easily fit in a 65 because it's WAY too wide(70.5 wide IRS vs a 68ish fender width at widest point) but is probably the coolest and most driveable option. A stock 8.8 from an explorer will give you problems due to the passenger axle being like 2 inches wider than the drivers axle. My dad put an 8.8 with a 3.27 and full spool in a 65 'vert a long time ago out of a 94 or 95 GT car. Damn near fit perfectly he said, but he used drums instead of disks... Cost became a factor and a basically stock 289/C4 wasn't making much more than 175hp to matter anyway.
Pretty much man, 8.8 is the best bet on a budget. Post 94 Mustangs also had 31 spline axles in them, but pre-94 was 28 spline. I think in 1990 the Rangers/Explorers/Bronco 2's received 31 splines.
8"> 8.8. IMO
I will rebuild the 8" I don't have enough hp to justify a 9" because bottom line is the world class t5 will always be the weak link,
The hieltz suspension is very nice, 4 link with coilovers and splines for 2k, then front ifs with manual rack and disk brakes 2k then just add the torque arm and axle cage
1k for a new third member
5k and it will be a real drivable car with some 17" staggered wheels
Buy that's a lot more to spend on a car that really isn't worth that much
So rebuilding my 8" axle will probably be best option about 500
Then make a 4 link
Probably buy the ifs tho
SCSB
Build logs:
Best (edit:period correct) rear independent would be like the old jaguar but fuck doing a pad and rotor change on a car like that
SCSB
Build logs:
  • 3 weeks later...
My baby finally got her new teeth on
Pics in the am
Also hot the hood pin on so I can lock it down without the main brace that got scraped when I changed to the modern fan and radiator
All in all pretty happy with the car so far, it's come a long way in the 2 years I've had it
SCSB
Build logs:
Had to fab something to hold my slave here under/on te side if the tranny
BAB2D2BB-1A31-4BF1-8335-80F002DEF9D1-569
Also started cleaning off my old tires :lol2: about time right
462E3896-00D3-4E4A-BCE3-22B409F8F27A-569
And the money shot
A2C602DD-61DB-4734-A801-5ABB77CC6C7E-569
819B70A9-18CC-40AC-8F47-512CB0FF88BA-569
SCSB
Build logs:
Thought about new wheels/tires yet? Interested to what a set of SVE Drift's would look like on this...
I will probably pick up a set of torque thrust wheels
For now I just got another set for my wheels ordered, washed and waxed her up real nice. I still have a lot of little things to do install, just barely out the seatbelts in and the diver door panel on, but it's moving along, being drivable really motivates me
I also talked with a couple people who have done/seen/drove alot of mustangs and I think in going to drill new mounting points like Shelby did with the cars back in the day. this changes the stance and will get it handling quite a bit better.
SCSB
Build logs:
I'd be more than open so have someone photoshop some wheels on my car so we can all see some options
SCSB
Build logs:
