This is just the start of my build log. I have ran into a few problems I thought I would post to see if you guys had any ideas. I have already gotten my Kenwood KDC-135 installed, Line Out Converter installed (Preamps on the back of the unit went bad for some reason). I have Alpine Type R 6.5's up front and Type R 4x6's in the rear(no amps yet :/). The only problem I'm having right now is where I'll be running my power wire (see pictures). I am a little nervous about doing this, I've never had to drill into the firewall for any of my vehicles but it looks like this is going to be the only way. My other problem is how I'm going to build the box! (once again, see pics)
It's already pretty well confirmed I'm not going to get the 0.8 cft^3 @ 34hz by building under the seat, so I decided to make the box a little shallow, but a little wide and flush mount my SA-8 between the front and rear seats so they don't get in the way. Here's the pictures:
This is how small of an area I'm working with (amp is only temporary, SPL Audio Z2X820)
Yeahhh, not a whole lot of space. I know, my truck is very dirty right now but she will be cleaned up prior to build
Where to run power wire!?
Not seeing any entries over here
Where I was originally thinking of drilling into the firewall. Looks a little iffy with the A/C lines, though.
Center of the front of the firewall. directly behind the intake manifold... Possible points of entry? Those two bolts look a little deceiving...
Thought this would be a LOT easier than it actually is!
More photos will be posted as I progress. If anyone could help me out it would be greatly appreciated! Thanks guys!
2001 Toyota Corolla CE:
4x Crescendo PWX6.5's
2x Crescendo FT1-SE's
1x DC Audio lvl 2 M1 8 (looking for more)
Slot port box 0.7ft^3 @ 31.77hz
Rockford Fosgate R750.1
1/0 Knu wiring all around
Looking for XS Power D1200
I ran mine down the frame and thru the firewall on the passenger side
Man I'm glad I didn't lock this I get to witness two retards holding hands telling each other that it'll be ok because they are awesome.
I could help you out and let you know that there is an area for build logs, and this isnt it.
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
Sorry, I'm new to the forums :noob:
I just make my own holes. use the clutch knockout panel and drill.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Run it along frame, under your rear seat in the center theres a plug tjat comes out Thats were i ran mine
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i am stoked for what you decide to do. Check my build! Same truck!
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
ALSO! My wire is ran through by the AC lines. its just fine
My Truck Build
