Are kerf ports as efficient as aeroports?
Im doing as much research as i possibly can before i build this next box. id like it to be very efficient. but id like to know which is the most efficient type of port between a slot port, aeroport, or a kerf. i know a kerf is a lot of work, but ive got time and patience for it. Can someone please explain the pros and cons of kerf ports and what applications they work best in?
If it helps, ive got a vehicle and equipment list:
2007 Jeep Grand Cherokee SRT8
12" AA Mayhem d2 subwoofer
AQ2200d amplifier
2 stock batteries
all 0 gauge shok wire
EDIT: im talking about like a one sided kerf port. not all 4 lol
Nope. Nothing currently on the market is more efficient than an aeroport. Also, it will be hard for a port with corners (ie. square, rectuangular, triangular) to be as efficient as a port with no corners (a circle).
A kerfed port IS, however, a good bit more efficient than a regular square-edged port.
They are slightly more efficient than a slot port without one. But even then they are DAMN SEXY and thats why I like them.
Big 3 with Yellow Top
Depends on your kerf job and final port mouth area and expansion rate. If you build it identical to an aero then of course it will be the same efficiency wise.
Hammerdown... 1%
how could i go about doing that? could you link me to something? or show me a pic?
Do what? Its all in the final box design you chose.
Hammerdown... 1%
In a kerfed port design, the radius of the kerf can make or break the box. In any box under 10 cubes, I would use aeros for numbers, over 10 cubes, I am doing a slot port and then test with kerf from PVC to see if it helps or hurts. It isn't a one size fits all once you get to a very large box. That last part was just for a why not mention it lol.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
A kerfed square or rectanglular port simply cannot be as efficient as a round one because, for a given port area, the square or rectangle will have more internal surface area.
  • Who's Online   0 Members, 0 Anonymous, 1737 Guests (See full list)
