DC Sound Lab
No just hook the charger up to the batteries it will be fine
even with 16v batts/charger ?
i ask because i used to have a soundigital amp , so im kinnda used to be as cautious as i can to not blow shit up... lol
Do you have a seperate charging system? How do you charge 16v batts? Eitherway it souldnt matter to amp since its off
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Guest jesseadkins187
Well we've had this same thread in our Team section and I got stomped by 2.7 db.
In my last install the score was 152.3 this was in my rex using 2 xl 12's
And the standings are:
2k
  • mhart 147.1 NSPL 1 15"xl at
3.5k
  • Traks 151.9 meca using 15"xls street 3.
  • laurziere1 149.7 using 2 fi btl 18s
5k
  • Kbsmoker 148.3 using Lv5 18
  • Ami customs 151.1 using 2 Memphis M3 12
  • jesseadkins 152 using2 N2 18s
7.5k
  • CJ18 156.9 using 6 level 3 15s
  • Mattp 152.7 using two xl 18s
9k
  • Deepsliencer 155 meca using 2 18" gheyhems
  • Soapbox 152.3 db drag using 2xl 12's
  • Ana 155.6 db drag using 2 10's
  • Meathead?
  • 99s10walled 156.1 using 4 15s gheyhems
  • Poorboy6977s 154 meca using 2 lvl5 15's
  • woodzyspl 147 dbdrag using 1 xxx15 in a trunk
  • millertime1028 156.9 @ 39hz sealed in the kick. 56.3 legal.156.1 using 2 18" neos<br>
12k
  • Dc98hoe 155.6 dbdrag using 4 xl 18's
  • Chode 156.0 in the kick using 2 DC Neo 18s
  • Sackett??
  • CJ18 157.9 using 6- xl 15's
mine was actually 152.5 :)
Kick scores are a lot higher but I don't compete or test that way.. sealed on the dash is the most uniform imo.. not taking away from the outlaw competitors.. its just more real world to me..
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
2k
3.5k
5k
7.5k
9k
  • Meathead?
12k
  • Sackett??
:yaya::orly3:
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Mids/Highs Amp-MB QUART ONX4.125
Mids/Highs- Undecided
Sub Amp-DC Audio 7.5
Subs-4x DC Audio xl 18s
Alt- 270sp & 250sp Dc Power
Big 3 1/0
http://dcaudio.us/
SPL-LAB sells rep. for IOWA
http://spllabusa.proboards.com/
2k
3.5k
5k
7.5k
9k
  • Meathead?
12k
  • Sackett??
:yaya::orly3:
ya ya ya really... i even got proof ;)
mate got a 154 sealed dash from the 9k in a wall with 4 12" clarrions in a 4th order. subs did not last LOL but got a 154 :) we built that wall and burped it next day. so about 7-8hours building (includes drinking, going shops, returning shops we forgot wood LOL) and alot talking about shit..
dunno if counts as he not a member on any forum.
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
My best dbdrag score is 155.18. 1 12k 6 XL 15s.
We should put together a list of each style of metering for each category of amps that way it can be seen who is metering what in each one.
Iam assuming mine well be the same going from the ab1100.1 to 9k.. 152.7 sealed on dash.. 2X 15 neos.
OREGON STATE REP DCAUDIO & JUICEBOX BATTERIES
2x 15 DC Neos...
1 DC 9k
2 Sets of Hertz MLK 2 Mids with Scan Speak Tweeters
Zuki Audio Eleets
2x multicells
4 Runs of 1/0 back
2010 Subaru Outback
Mario I would definitely be careful running 1 5k per XL. Even with a custom spider pack to help compensate for the extra power, once the XLs hit 3000-3500w of clamped power you are going to run out of motor and start blowing/breaking subs. I personally do not like pushing my equipment to the breaking point. Right now with the 1 12k running to 6 XL 15s with my voltage starting and not budging from 15.8 at full tilt, I am able to beat on the all day with no smelly coils or any problems whatsoever.
From my recent experience while I was running my Level 3s, once I started to reach motor saturation my subs really started to heat up and get stinky even with perfectly clean power. Once the motor becomes saturated, the extra power has to go somewhere and is burnt off as heat and will start causing problems for you and burn your coils and result in multiple recones being needed.
im going to have them wired at 1ohm. Its always better to have more power than not enough IMO :shrug: I do not Beat on my system daily I think they will be fine but we shall find out. :santa:
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
