cant give info without knowing subs/amps being used
I know. I just didn't want to jix it. but I'm building the box for two Skar VVX-15s. Not sure on the amp yet.
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
Why do you have 1 for bracing displ?
Because the braces will take up about 1 cu. ft. of displacement.
That dowel takes up a cube? No way..
EDIT: I see you have the 45 in there also, but that still can't be a cube.
Edited by loudNlow87
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
stick around 5.5-6cuft for rms
id use about 60-70sqin of port
bracing does not take up much volume. i can well brace and 45 a box for 2 15s and its usually under .25cuft of bracing
Thank you! I was giving my self some slack.
Youtube Channel
That's what I usually use when bracing box, 1 cube is gonna be hella of a bracing :lol:
use like .1 or .2 for displacement on bracing
Edited by LoudBimmer
Ok here is a revised version of the design. In the sketches I left out the bracing, but there will be 45s in the corners and a rode between the subs connecting the baffle to the back of the box. Hopefully this one will be okay. I am hoping to start building the box this upcoming weekend.
The black circles in the box represent the magnet, to see if there was clearance for the ports. I wasn't sure of the magnet size so I guessed 8" diameter.
Youtube Channel
Looks much better, but you need to make sure the ports are at least the port diameter(4") from the bottom of the box. 4" would be better than 2.75"(you have to calculate thickness of wood when thinking about distance). 18.5-15=3.5" and 3.5"-.75"=2.75"
Edited by CleanSierra
  • Who's Online   0 Members, 0 Anonymous, 549 Guests (See full list)
