im about to start building a box for my 2 12" skar audio. it looks right to me just making sure its right before the build so is it all good?
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
only thing i could nit pick would be whats ur plans for bracing and 45's in the box? for a box that size prolly be about .15 displace if you used good bracing and 45ed the corners
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
yea im gonna but some bracing thats why i made it a little bigger then i wanted and tuned a little lower. and ive decided to do 3 port walls all it changed was the tuneings a little lower and it raised the net volume about .6
and bracing should take up around .15? for 45 corners and wooden poles going up and across.
Edited by new guy
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
Could you please tell me how u got port length and width? I want to learn so bad
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
how i learned is i just got on torres and started messing around with it.
what you should do just get on there and try to design a box for something simple like a single 12.
try to get it to tune to 30.
keep the port area per foot between 12 - 16
keep net volume around 1.5 - 2 cubes.
just start throwing numbers at it.
eventually you will get a good box
then try another box. after a while you start to get it down and it gets easier and easier every time you do it and you learn what changing the dimensions will do.
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
