just doesnt make sense
mbdblue
is that blob before or after the fix....?
after, we added a little too much, but tried to fill the cold solder that was there.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
the thermal paste?
yeah, the thermal paste....there was still a TON of it on the case itself.
Ok good. I tore apart a power acoustic that was insta-protect on power up and there was the bare minimum on that thing. Fixed it up put new paste on and let my buddy hook it up. Didn't watch cuz I thought he knew what he was doing and loaded one channel with 1 ohm. Smoked in less than 5 minutes.
Edited by Lbox88
Did you make sure it bonded to the board?
As to thermal interface material, you can get it dirt cheap. Just use wheel bearing grease ; ) Oh, and for the record, more is not better. If you've got a poor surface to surface connection and no pressure then adding TIM between does nothing to help. Fix the problem otherwise the TIM is just a thermal insulator.
Hammerdown... 1%
yep should be fine man, We did front and back to make sure and I was watching him feed it in
edit: believe me man, Im not wild about fixing my own amp, (one of the reasons I sent it out) but I trust my friend knows what hes doing.
Edited by mbdblue
  • Who's Online   0 Members, 0 Anonymous, 1287 Guests (See full list)
