Hi guys, how will this sound, will it be ok? 4x RE SE 15" in 8 or 10 ft^3 total tuned at 34-35Hz? thus giving each like 2 or 2.5 ft^3, I know RE recommend 3ft^3 Compact and 4ft^3 optimal, but could they work in smaller ported enclosures?
Also wich one of these two you guys will choose: 4x RE SE 12" in 7.2ft^3 Ported tuned at 34Hz or 4x RE SE 15" in 7.2ft^3 Sealed.
Anyways thanks i need some opinion/advice before i make decisions
Shaking The Neighborhood.
if the lowest RE recommends is 3 cubes for a 15...i'd try not to go smaller than that. the enclosure can make or break your setup
EDIT: damn typos :mad: :mad:
Edited by ExpoSport
i would do the four 12's if you only have 7.2cubes to work with...and if that is after all displacement, otherwise u should cut the number of subs and could probably do two 15s
i likes me some audio stuff...
Yea definatly!!the box can definatly make or break a setup so yea i wouldnt go ne smaller than the recommended..and i would go with a ported box!!i used to have 2 12" RF P2s in a small seald box and it sounded ok but then i cut 3-1/2in holes and stuck 2 3-1/2in aero port tubes in it and you wouldnt believe the diff. and then i went to a 6cu.ft. box at 32hz(my current box) and now i have the 2 12" TC-1000s in and i am rite round the low to mid 140dbs ;) ..so deff ported!
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
thanks guys, so you guys recommend the 4x RE SE 12' ported compared to the 4x RE SE 15 sealed, will the 4x 12" ported be much much louder than the 4x 15's? thanks.
go for the 4-12ers that will be louder yeah, you can also do more with your enclosure, is not good if RE recommend 3 cu/ft a 15er to go under the 3 cu/ft just go for the 4-12ers that will be good choice, AND LOUD
Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps
