Torres Posted November 23, 2011 Report Posted November 23, 2011 not in the corner. as long as you keep the port area consistent throughout the whole port, including the corner where the 45 is, you're good to go. you don't want the distance from the corner of the port to the 45 any smaller than the width of the port, or that will pinch the air some. Quote
Jd1102 Posted November 23, 2011 Report Posted November 23, 2011 not in the corner. as long as you keep the port area consistent throughout the whole port, including the corner where the 45 is, you're good to go. you don't want the distance from the corner of the port to the 45 any smaller than the width of the port, or that will pinch the air some. are you sayin like orionstangs pic or just in general? Quote
Joe X Posted November 23, 2011 Report Posted November 23, 2011 But since the turn is smoother the losses on the turn will be lower so tuning has to change a bit. Anyhow with properly calculated port area and H/W < 9 you should not need any port smoothing. Quote
