A quick test that you might get lucky on is try tapping on the mass air flow sensor and see if the car starts to run bad when tapping on it, if it does thats a bad air flow sensor.They have a computer chip in them that could go bad. Good luck.
Member of Team 808
Member of Team North East Spl
Alright back from messing around on it. New plugs and wires, much better throttle response but my problem persists.
Ran the codes and only O2 sensors came up. Put it on the lift and discovered... HEY! previous owner removed the front two O2 sensors. Sketchy fuck.
I am guessing this is causing sensors and what not to go out of whack
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Missing O2 sensors are causing the computer to get confused, therefore your problem. The reason it goes away is because Ford computers figure out the problem and correct it in about 3-5 minutes.
Awesome man, thanks for the info! Ill get some sensors soon and update how it goes
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
