Advice on putting together a daily 150+ DB system
Looking to do a daily driving build that can do 150+ but wanted to do a minimum of 2 15's or 4 12's. I was thinking either 2 AudioQue HDC4 15's or 2 AA Mayhem 15's. This will be a trunk build in a 82 Cadillac coupe Deville around 7 cu ft to play with. As far as the amp goes. I was going to use either a Crescendo Audio BC5500 or a Stetson 4k5e. Still undecided with the enclosure but speakers will be facing the cabin (sealed to eliminate noise cancellation). Need some advice. Im trying to take advantage of the online Black Friday deals.
well im 0.6 db away from 150 on music in an extended cab s10 with 3 4k amps getting about 8k total with 3 12in dc xls and i peak at 27 hz so you will need to face them subs forward and seal off from trunk , its not impossible just hard with a trunk but gonna need some cone area, power, and good design and did i say cone area, power, and GOOD design .
2 12ks and i dont know what to do
build in the works!
enclosure design will play a large role as well as power and cone area. supplying your amplifiers with the power needed is also a must. both amp choices are sexy so choice depends on personal choice along with whatever will give you the most power at your voltage and ohm load.
That car has a huge trunk if I'm not mistaken.. with a upper package tray shelf.. id go with maheyhems and the crescendo.. then a ho alt and multiple batterys.. and go with an experienced box builder.. that's the key...
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
FI is made my Ascendant Audio. Building a 150 daily in a trunk is not easy to do. Take a look around the build logs at some of the trunks to get an idea what it takes.
  • Who's Online   0 Members, 0 Anonymous, 1151 Guests (See full list)
