I installed my new headunit, everything was working fine untill I started driving around. I was on this bumpy road and then the sound started cutting in and out then poof.....my audio was gone lol. The h/u is still on and is charging my iphone but no audio from aux or radio. What could be wired poorly so it would not get sound to any of my speakers? I understand if I had one of the speaker wires hooked up bad and it had stopped but for all of them to stop working what wire would do that? o.O. I was so happy I got my first install done all by myself then this shit happens lol.
Fi X12
AQ750
Pioneer DEH-6300B h/u
pull radio out. slightly tug each wire at the connection point (butt connector, solder joint, whatever). if it feels loose or comes apart, you know you have a bad connection and likely more.
check all the speaker wires and make sue the aint touching
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
If all your speakers stopped sounds like you have a speaker wire loose or pinched and may be grounding causing your outputs to fail... check each wire closely!
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Well I'm out in my car now and I was just checking to make sure the everything was in tight and it's working now lol. I'm going to check each wire tomorrow when I'm not workin in the dark. Thanks for the help guys.
Fi X12
AQ750
Quick question think this would happen from having my RCAs and remote wire plugged in but having them just sitting on my floor not hooked up to my amp? Cuz i unplugged my RCA cables and then it started working again. dunno if it was just a coincidence or what
Fi X12
AQ750
