HIDExtra is having their cyber monday sale. i can get the standard hids hi/low for $30 so im considering it
it is a 35w 9007 bulb and the kit comes with this:
Two (2) HID Bulbs
Two (2) Digital Ballasts
Two (2) Wiring Connectors
Two (2) Mounting Brackets
Installation Manual
now there is a drop down box for two things that cost $10 a piece, one is a cancellor and the other is a relay harness
what are these two things and do i really need them?
last question is how hard is it to install hids? do i need to hack up my housings to make them fit? and how long do the bulbs last?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Most of the time hids are plug and play, stupid easy. The only other thing id add is the relay harness. That just pulls power from the batt to help power the ballasts. Simple power and ground hookup. They pull very little power though. Reason I say to add it though is cause in my burban I can see my voltage dip ever so slightly when I turn mine on, and I don't have the relay harness
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
depends on your car, should be a direct fit for most newer cars without the extras.
Start out boxy, shape as you move along.
Dc Audio
Team Fur
:good:
that way it prevents flickering and they turn on every time, sometimes with out it only one of the hid's will turn on, other times both so with the wiring harness they have their own power source and dont have to worry about it
the cancellor you mentioned might be for the cars that tell you u have a headlight out, the hid's take more power to start but when they are on they run on lower power and so the car might think it has a light out.
i say go for it, youll never go back to halogen junk
thanks for the info guys
and James the ones on ddmtuning are the same price but cost $20 extra for the hi/low then the harness is another $15
lifetime warranty is cool though
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
nowhere did you say you wanted hi and low beam that i seen. Also id never buy a relay harness anyhow when a relay is less then 5 dollars and you can wire it yourself..IF you think you need it.
first sentence :)
thanks for looking out though. i really do appreciate it
i feel you on the relay thing too.
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
first sentence :)
yup im a forum noob....havent been on much lately so im blind lmao.
first sentence :)
lol
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 627 Guests (See full list)
