I'm going to be getting two Skar VVX15s, seening about 600 - 800 watts rms, along with four 6.5 coaxial speakers running off a MBQuart ONIX80.4. This is all going in a 1994 Mazda B3000.
My questions are:
1) Will the stock alt and battery be enugh?
2) Would a battery bank affect the cold cranking amps?
3) What should I look for in a good battery for a battery bank? (Xs batteries are not an option, due to shipping)
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
Put a big Xs power batt under hood ..do ur big three in sum good ofc 1/0 and to ur amps and you'll be good....make sure u have solid groundsj!
2001 Grand AM
Pioneer UB4000 HU
Tsunami / Monster Wire's
DC POWER INC 260SP ALT w/ XS Power VCM
BIG 3 All 1/0 Monster 400 + YT Under Hood
Stinger SPV70 x2 in Trunk
4x SA-10's On There Way soon i hope
SS XXX-4000D @ .7ohm 3K+
RF Power 4x6's & 6x9's Monsoon Powered
PG TL22 Line Driver
148.7db @ 35-45hz sweep w/ 12" BTL
My questions are:
Electrical upgrades should always be first. You might get by with the stock alt if its enough to charge your future batts. But id upgrade under the hood and have a batt near the amps. Im not sure what you mean by effecting the cold cranking amps. Id look into running about 120-200ah worth of batts for said setup. If you had a h/o alt you could get by with a little less
American Bass*DC Power
The h/o alt for my truck is $500 plus shipping. I just want to know if I can make it through winter with what I have. I forgot to mention that the big 3 is already done.
Youtube Channel
well how big is the stock alt? if its like 60 amps, i wouldnt even try it. i googled really quick and found 95 amps. with the big 3 and a big battery in the back (or front) and you watch your voltage, i dont see why you should have any problems.
My questions are:
I like how you say xs is NOT an option, yet the next post( sactown) says to get a xs under the hood. Did you eeven read his post? LOL.So sanchez, are there any other power cells avalible ? Like kinetic, or atleast a yellow top?
Member of Team 808
Member of Team North East Spl
I belive mine is a 95 amp alt. I'm just trying to plan out my build befor I get to far into it. So if I can run am extra battery I will be one step closer when I get the money for the alt.
Can I use any batteries? I'm worried about cranking amps. The last thing I need is for my starter to blow. Or does that even matter?
Youtube Channel
Doesn't matter on the starter if it's 1000 or 1500 it's gonna be a lil faster on 1500 amps but that's about it. I have over 2000 cold cranking amps on tap. My truck loves it!!!!!
1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
  • Who's Online   0 Members, 0 Anonymous, 3171 Guests (See full list)
