i was wondering if these trim rings were important on the subs and when you mount them.
i was hard for me to mount the subs with 1/4" bolt and using t-nuts.
so i removed the ring and mounted them pretty tight to the baffle.
u cant put your fingernail in between.
but i wanted to get opinions if it is important to use them, like a gasket?
thanks,
larry
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
it just helps to seal it. thats all. Not gonna affect anything as far as i know.
thanks frozn,
i thought thats what it does but i also thought it made a sub look prettier.
so there is no downside to removing the trim?
HMU!!!
95 Bonneville SSE
thanks frozn,
Im like 99% sure there really isnt anything wrong with it. I almost had to do it with my lvl 4 15" because I thought it wouldnt fit in the box with the gasket on. but it did. As long as its tight its good.
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
cheapo Legacy coaxes (just for now)
Is that like the rubber one that the dc's come with?
yea, i took it off.
HMU!!!
95 Bonneville SSE
yea, i took it off.
Yeah, the ring is cosmetic on the outside and help seal on the backend. It won't hurt to remove it as lnog as you are doing something to back an air tight seal where the frame meats the wood.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
