What up smd brethren, so I have this old '84 F250 with a 460cu.in. 7.5L engine and I'm trying to find a bigger/better secondary alt for it, but there's nothing but 60/70 amp alts..
So, my question is: Can I just get a 100+ amp alt from say a newer car and just put it in there(with custom brackets of course) just hooked up straight to the battery? Will it work properly just like that?
EDIT: Reason I ask is because I eventually will get to doing a blow-thru with 2 15hdc3/4's, so I want to be sure I can keep my electrical strong.dirol.gif
Edited by AUDIOADDICT02
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
nice builds
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
yes you can install any alt to it with some brackets made for it
Ok, cool. I had to ask because alts have a + output straight to the battery, but they also have those extra wires that plug in, I was wondering if it affected the alt's charging potential if those other wires were not being used..
nice builds
Thanks?
..btw, I'm in the process of repairing my truck from the first post, so more than likely I will be able to work on your ride during the week since my carburetor ain't coming in 'til Monday.
i added a 3 wire alt to my truck just a few weeks ago, i did one straight to battery then got a resistor from radio shack and ran that wire to the ignition and the other one to a power distribution block and it is charging 14.4 now. you can google it and find wiring diagrams for alts and you can also put GM alt on a ford
Ok, but do you absolutely need to use the other outputs on the alt if it's a secondary alt? Also, I'm not trying to replace the original alt in my truck, it's only a few days old.
I have a Nissan Versa´s alternator on my suzuki swift, works awesome :)
yes you need to use all wires for it to charge not unless you get a 1 wire alternator
if you get same alt you can just tap into the existing wiring.
Edited by Miguels
