Sub barely moves?
did you wire the sub to the correct ohm load for the amp?
Also could be half-dead amp or bad power/ground connections.
Hammerdown... 1%
I think I might of found the problem lol
Look inside the RCA input on the amp. The metal tip should be buried in there. I've seen this happen before with 2 or 3 other types of RCA's (not Knu). Pull the tip out with pliers/tweezers and shove it back onto the RCA
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
That was for me?
If it is, the subs are wired correct on 2ohm and the amp 2ohm to.
I took the amp to do some test on a eletronic. I will bring it back tomorow maybe.
Then if every thing is ok, test again another ground point and take a wire direct from the engine battery.
That was for me?
no, soundofviolence
Hammerdown... 1%
  • 3 weeks later...
Hey guys if anybody is wondering i got it all fixed now. I just got my amp back too! here is a little video of it going to work.the camera didnt pick up stuff moving as much as it should of but you get the point. also dont mind the ghetoo bricks in the back. it doesn't even compare to most of you guys systems but hell its my first start :D.
Fi X12
AQ750
Pioneer DEH-6300B h/u
glad it's working fine now, it's the little things that can cuase big problems.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
glad it's working fine now, it's the little things that can cause big problems.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Fi Audio Q 10s
Big 3
Singer Alternator
Sky High Wire
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
