~ iPad inDash SQ Rebuild ~ Scion tC 2006 Old Alpines, Sundown, Pioneer, Mechman
Damnnnn I need to get to work on mine! Those look amazing!!
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
So how does it work Hunter? Make your ring, glue it in place, then stretch the fabric over nice and tight? Then a light coat of resin to get the cloth wet. Then a second thicker coat to seal it up, and then everything after that is just build up? sand and that's it? I'm guessing as long as the cloth doesn't give you shouldn't have much if anything to fill right, like what you've done?
Thanks for all the compliments guys,
The suede sucked it pulled apart that's why there's a couple very tiny wrinkles on the wrap but it wasn't noticeable and enough for me to redo them, plus I didn't have any fabric left. I think it's called unisuede actually made for seats so it wasn't stretchy at all.
Yeah basically exactly how I have it pictured shows all the steps. Make ur ring, flush mount or not. I used hot glue to hold it into place while the a pillar is in the car. Then I add a coat of resin on the stretched fabric. I lay it on thick as I can so there's an even spread. As the resin hardens after around 30 min for this epoxy resin it gets tacky, I then mix another batch and add resin on top. In total I think I did 3 coats and 1 initial. No fiberglass mat or bondo or any reinforcing was used. I wanna show that there is NO need to put layers of mat on a pillars or most fabrication. 95% of the time people over kill things and it makes their lives and work much harder and longer.
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
So in other words, for your process, you need the car to do pillars? Lol...
Nah just need the pillars. Unless ur extremely Anal about placement such you want the right one hitting the right ear with driver seat 75 degrees back and the and left one hitting the left ear. Besides that everything is done outside of the car. I just did one inside the car and then matched the other outside of the car
Scion tC SQ Build
  • Who's Online   0 Members, 0 Anonymous, 1762 Guests (See full list)
