The "1500" watts amplifier CHALLENGE!!!
fecupe2001
Maybe you could save some money and get yourself an AQ1200.1 , it´s supposed to be a VERY similar amplifier, i know "gumbysmoke" clamped his and posted a youtube video on his channel a few months ago but he erased that vid, he was getting something like 1900 watts iirc :)
I just read the entire thread...I decided to compile the results so far
Audiopipe AP1500.1 (1500 @ 14.4v)
Hifonics BRZ1200.1 (1200 @ 14.4v)
Digital Designs M1b (1200 @ 11.9v)
Digital Designs M2a (1600 @ 11.9v)
Cadence ZRS 7500D (1800 @ ??)
Hifonics BXI1608D (1600 @ 14.4v)
Rockford Fosgate T1500.1 (1500 @ ??)
Hifonics BXI1610D (1600 @ 14.4v)
Audiopipe 1500.1 *TL score -146.58 @ 42hz*
Clamp results :
Voltage drop: 13.6v
44.6 Volts
41.7 Amps
44.6 x 41.7 = 1859 watts
44.6 / 41.7 = 1.06 ohms
Hifonics BRZ1200.1 *TL score -145.7 @ 42hz*
Clamp results:
Voltage drop : 13.9.v
39.2 Volts
35.5 Amps
39.2 x 35.5 = 1391 watts
39.2 / 35.5 = 1.1 ohms
Digital Designs M1b *TL score -147.8 @ 42hz*
Clamp results :
Voltage drop: 13.5v
49.1 Volts
45 Amps
49.1 x 45 = 2209 watts
49.1 / 45 = 1.08 ohms
Digital Designs M2a *TL score -148.5 @ 42hz*
Clamp results:
Voltage drop : 13.2v
52.1 volts
48.1 amps
52.1 x 48.1 = 2506 watts
52.1 / 48.1 = 1.08
Cadence ZRS 7500D *TL score -147.3 @ 41hz*
Clamp results:
46.7 Volts
43.5 Amps
46.7 x 43.5 = 2031 Watts RMS
46.7 / 43.5 = 1.07 ohms
Voltage Drop : 13.7v
Hifonics BXI1608D *TL score -146.7 @ 42hz*
Clamp results:
43.3 Volts
42.2 Amps
43.3 x 42.2 = 1819 Watts RMS
43.3 /42.2 = 1.03 Ohms
Voltage Drops : 13.8v
Rockford Fosgate T1500.1 *TL score -147.4 @ 41hz*
Clamp results:
46.9 Volts
44.3 Amps
46.9 x 44.3 = 2078 Watts RMS
46.9 / 44.3 = 1.06 ohms
Voltage drop : 13.9v
Hifonics BXI1610D *TL score -146.6 @ 42hz*
Clamp results:
41.9 Volts
41.2 Amps
41.9 x 41.2 = 1726 Watts RMS
41.9 /41.2 = 1.02 Ohms
this is awesome that you sir. this would be good for the first op post
excellent compiling!! Fecupe post that up on first page :clapping:
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
]Thanks a lot for the compile, results posted on the first page :)
My pleasure, you did all the work so I figured that's the least I could do :) Just realized this has me logged in through my FB page...I'm Oldbasshead....
Thanks mate :drinks:
  • 2 months later...
Sorry I know this thread is kind of dead right now but I wanted to clarify something. It appears from what I have read clipping wasn't taken into consideration with the testing. I have a brz1700 and it will not do rated power at 2 ohms without clipping. Can you maybe use a scope for the 2500 watt challenge?
noo the results were with a clean signal. look at o-scope on TL its a perfect sine wave
BMW M340 xDrive
