Sub: SOLD
Amp: $350 shipped
Main Features
3000W x 1 @ 1 Ohm RMS
2000W x 1 @ 2 Ohm RMS
1000W x 1 @ 4 Ohm RMS
6200 Watts Daisy Chain Output Power @ 2 Ohms
Frequency Response 10Hz - 400Hz
Signal to Noise Ratio @ 100Hz: >90dB
Total Harmonic Distortion: <0.05%
Common Features: Remote Bass Control Included
Strap Two Amps Together for Double Power Output
Oversized Power and Ground Inputs with Heavy Duty 4-Gauge CNC Machined High Efficiency Power & Ground Inputs
24dB/Octave Electronic Crossover with Variable LPF 9 Low Pass Frequency) from 20Hz-1.5kHz Plus a Separate Variable Sub Sonic Filter
Self-Diagnostic Protection Circuitry
Dimensions (W x H x L): 10.51" x 2.56" x 20.87
THe sub I just bought and is basically brand new. Guy never used them. I was going to use it, but after trying and trying to figure out how to fit two in my car, just isn't happening, which is why it goes bye bye. The amp was purchased off of DWright and needed repaired and I shipped it to DB-r. When they got it, there was nothing wrong with the amp, but with the bass knob, BUT this is what they did do:
dB-r Customer Service
10/20 16:03 Ok these are ready. The only thing we found wrong was in one of the amps that went right into protect every time, was some bad transistors in the protect circuit. It was only 2 that were bad, but there are 4 total there, so we replaced all 4 for good measure. We could not duplicate the problem in the other amp that you described (turn up volume goes protect) but we went ahead and replaced those same 4 transistors in that amp also just in case they both had the same problem. If you still have a problem with this amp, it may be the bass knob or something, not the amp, just let us know if you find it to still have a problem.
The amp does have feet and will be in the PB box, but no knob since it is bad. I use the PAC knob now and according to some, it is a better option anyways.
IF you by them together, I will do half the shipping...depending on location.
NO trades unless you have an English Bulldog puppy, or an Alt for a 2005 VW GTI. :drinks:
Vid of it playing
10501650_10203332501847103_1859383749711
Blown
So are you selling both subs or just 1
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
What Coil's and the rms I cant find just btl on FI site just btl n2 - n3
Hi SMD Members If anybody has computer problems and is an SMD member with at least 150 posts I will fix your problems for free by phone support or I can also fix your computer over the internet.... I have references such as All State insurance, Nationwide Insurance and much more... just p.m me for help.. I am not the greatest with when it comes to audio systems so I figured I could contribute to the forum this way.... Thanks David
It's an older model sub they won't have it on the site its a dual 2 rated for 2k
Sub to 14224?
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
It is only one sub.
Sry. It is a D2 and if you look in the Fi section here, they still list the specs. Krypt, it shows $48 thru UPS, so give or take with insurance and all. It will go out in the box it shipped in.
Blown
