Can u guys pls help to clear things up for me?
Ive always hooked my speakers to the + and the - u know as one would ussually do, but then ilooked at the sundown mannual and see they state a + to + connection for 2ohm load.
http://www.sundownaudio.com/pdfs/SAZ1000D_1500D_3000D.pdf
Can any one explain this to me
Thx
Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice.
Build Log>>>
http://www.stevemeadedesigns.com/board/ind...pid=672024&
New Build
Believe in the order
its giving you a diagram for dual and single voice coils, two + would be for dual , and one + would be for single, note its note showing you how to lower or raise impedence.
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
Are you missing the negative down bottom? There's two positives to show that you can use either side. Look close and you'll see that it's broken into three sections "[+] [--] [+]"
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
they dont show you to put it in both positive but you can choose in which you would like to have the positive
Headunit - Pioneer AVH-P4250 DVD
4 - infinity reference 6.5
a pair of infinity reference tweeters
1 - AudioQue AQ-120.4 amplifier for mids & highs
1 - AudioQue AQ-2200D Monoblock
1 - AudioQue HDC315
KitAudio kerf ported Enclosure
4 - Stinger pro series signal wires
20ft Stinger 1/0Ga power & Ground wires
Big Three Upgrade
1 - Kinetik HC1800 (Not Here yet . .Still Saving up for one)
This is what I think is going on
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
its a mono block amp,1channel, it has 2 speaker inputs ,but you dont have to use both + or - its just there to help with wiring. for raising or lowering impedence.it dosent matter wich side you chose to use.
Edited by Bmike
pioneer m650 pros
Yeah thanks guys.
For now its single sub Duel D1 and single amp wired to 2ohms.
SAz3000D to be exact.
I have always wired it like +(con) - (c0n) -(emp) +(emp) for single sub use.
However when I checked it sort of looks to me like the lines are going directly to +(con) and +(con)with nothing to the -
Seems strange to me for a diagram that other wise looks very detailed.
*edit on second glance on pic 1 page 8 clearly show the - connection I suppose the two + connections threw me off.
Build Log>>>
New Build
i see what your saying the diagram is a bit misleading,yes you will need to use both +,-, wether or not you chose to use both channels is totaly up to you, depending on wether you wire it up to 2ohms at the sub or on the amp.im useing the 3500, so i have had the same thoughts at first. heres a pic dual 2ohm coils, each coil ran to amp, one on the left side one on the right, 1 sub,wired to 1 ohm
http://i40.tinypic.com/mr322q.jpg
Edited by Bmike
pioneer m650 pros
  • Who's Online   0 Members, 0 Anonymous, 1747 Guests (See full list)
