SKY HIGH DC MONSTER GMC SHORT VID LINKED TO FLEXING SHOP WALL
the way i did my battery bank(which will be under the wall) si as follows
Dual batts up front. one on each side
Three runs positive and negative to the back from each side.
since I couldnt link the batteries in the back under one bussbar I did 3 per side in the back. each side is linked together and then three runs from each side of 4/0 link to a center buss bar that goes to my amps. im anal about trying to keep the runs all the same length or close to it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Those amps look sexy like that and the console is going to be fun to sand.
thanks man!! and god do i know that lol hours of bs to come lol
Cooming along nicely
thank you
What kind of sander do you have btw? I just bought a brand new orbital Ridgid from HD (Gift cards ftw) and they still come with a lifetime warranty, thought that was kind of amazing compared to others lol. Think it was about $60~$70 before the gift cards.
i normally sand everything my hand or with the numatic (however its spelled) sander.
if it will help me do this and the head liner quicker send me a link to it please :drinks:
^^I have no idea. i would say no as long as they are close. The ft difference for instance my amps will see from far right on the rear amp to far left inputs on the front amp shouldnt make a difference. i mean current travels so damn fast its insane and over a ft i bets its like a nanosecond difference. i guess on my bus bars in the bed all the leads cannot all be at the exact same place so i guess i could move the leads which are closest to the amps down the bus bars so they are a lot closer to all the same length. that would work well to make them real close. but bottom line i have no idea lol
Someone else please chimp in who knows better than me sorry man
Here is the way it was explained to me by Mike Singer.
You will have 12 runs of power running into the truck from the batteries, 6 to each amp. If you have say 10 batteries connected together in a row by buss bars. You are now running all of your power wire into the driver side of the truck. If you were to run all 12 wires off of the 3-4 batteries on the left side of the bank, you are going to draw more on those few batteries and not as much on the other 6 on the other side of the bank. If you were to spread out the runs over the entire bank of batteries, you are now drawing evenly across all of the batteries instead of focusing all of the draw on just part of the bank. If you focus on just one part of the bank, you will still use the other batteries, but you will be drawing harder on just those 3-4 instead of dispersing the load evenly across all of the batteries.
hmm will it make a difference with the length of the wires going to the amps. maybe i can just do 2 rows of batts so the bus bars are shorter and hopefully making the amount of power coming from each batt as close to equal as possible.
it sounds like an issue i do not want to have the only worry is the lengths of wire. if you could answer that one for me i will do it right the first time lol
thank you very much for your input i appreciate it man
Contact us for the best quality cables and accessories with the fastest shipping in the industry
EMAIL: [email protected]<script data-cfhash='f9e31' type="text/javascript"> /* */</script>
LIKE US ON FB: https://www.facebook.com/SkyHighCarAudio
ADD ME ON FB: https://www.facebook.com/jon.rabe.1
MONSTER SKY HIGH/DC GMC: http://www.stevemeadedesigns.com/board/topic/127057-sky-high-monster-gmc-walk-through-12-lvl-5-15s-6-9ks-trim-panels-and-wiring-p-90/
how thick are your buss bars and what material? Heres the good thing. Its in the bed. IF they start to get hot then you have issues. You can then swap out with a perfect template for a new buss bar in a thicker material.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
hmm...so if i did a bus bar on mounted onto the inside of the battery box then linked all the batts to that buss bar then all the +/-s from those bus bars to the amps. would that make the batts draw close to equally? or am i mistaken?
im acting like areal noob right now!
no that should cause even draw. here this might help you.
everything is exactly the same. Each battery has one run coming in directly to the terminal. Each run to the bussbars in the center is drilled in exactly the same place.
If you did a bussbar on the side of the box it would be just like the one I did in the middle. It would add another point of failure if it would fail and could be considered a weak point. I had no other way to do it. If I were doing your truck I would skip that. I would just make sure that each run came from the exact same spot or very close to it on the buss bar. What I mean by this is if you take one run from right next to the battery for one. Take the other runs from the same place near the other batteries.
How many batteries and how many inputs do your amps take?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
So yesterday i got the headliner fully dry and could start cutting it down to hopefully get it up (after its sanded and shit) so i can do all the flush mounts and the sealing parts from the box to the b pillarsHeres the pics188headliner.jpg189headliner.jpg
Did you cut that thing with a sawzall!?! EPIC! I love it!
So i got the 12ks up today and the fans mounted and wired up. 19812ksfar.jpg19912kswindowdown.jpgIf someone is trying to play their music loud around me they will just see this...no need to even turn it up because i highly highly doubt anyone on the streets around here will be louder....with an exception of one van haaha but im comin for it lol
GAWD DAMN THOSE ARE HUGE!!! I had no idea those amps were that long! They must be heavy! I feel like I'm talking to a pornstar with size double HH's. HA! Only I'm really talking about the amps! They really are sexy! And I love the way they play peekaboo in that last pic with the window down! Awesome!
Shits coming along nicely! I'm liking the center console. The only thing I'm kicking back and forth is, under the double din spot, it almost seems like it should flow into the bottom instead of diving back in. Just seems, to me, that it would flow better if it ran right into the flat part. Just a thought.
Keep it up man! I love this build!
The power shit is so far over my head guys! I can't even wrap my head around 6 runs of 1/0 ga from front to back. It's just crazy to me! But I've never done a build to this magnitude! YET! I would love for you guys to work with me on a blow through on my truck! One day!
Sorry! Keep up the great work! Lovin it!
ok yes that helps. i will have 10 batts in the back and 12 + and 12 - inputs total (dual inputs on each 12k)
haha yes they are fucking unreasonably big and i love them...talking about the amp not your porn start with HHs haha
The HU had to be like that to keep my room for my switches, volt meters and VCM from XS lol i agree but to fit everything that needs to go there it had to be done like that unfortunately.
no problem man when you are ready im sure people will be there to help you just like they are helping me with this battery draw shit lol
but i got it now!! gonna use those batts to their full potential
http://www.homedepot...catalogId=10053
Haven't even been able to use it yet, weather has too fucked up and then trying to buy a house after work leaves me no time for anything else outside lol. I bought it though because it was a tool I didn't have and all the other ones I was looking at only had 1-3 year warranties.
That is such a great reason to buy tools! I use that all the time! Me: Honey I'm headed to "the depot" to get (insert tool here). Wife: Can't you use something you already have, instead of spending money? Why do you need a new tool? Me: Umm, cause I don't have it now, and I need another one! Wife: But if you don't have one why do you need another one? You have enough tools already don't you? Me: Nope, don't have this one. If I had it I wouldn't need it! Wife: Sigh! Pretty much the way it works!
Is that the variable speed one? The one I have is exactly like that, but I think mine is variable speed. It has a knob on the top front of it. GREAT for sanding glass! Pick up one of those cheapy multi packs of sand paper, like 100 discs in a pack, and you're home free! Detail sand by hand! WINNING!! :yahoo:
