mattc3366 Posted December 8, 2011 Report Posted December 8, 2011 Hey guys just got my wire in and planning on doing the big 3 this weekend. I've read the guide on how to do it but my only question is about the wire going from the alt to the battery. I think I've seen ppl saying you don't have to fuse it? Or fuse it to be safe? If your supposed to fuse it what amperage fuse should be used? A little over what the alt puts out? Thanks in advance subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch
Watch the bass Posted December 8, 2011 Report Posted December 8, 2011 Hey guys just got my wire in and planning on doing the big 3 this weekend. I've read the guide on how to do it but my only question is about the wire going from the alt to the battery. I think I've seen ppl saying you don't have to fuse it? Or fuse it to be safe? If your supposed to fuse it what amperage fuse should be used? A little over what the alt puts out? Thanks in advance Big 3 read it again, fuse the wire, i like this guote very well "Use fuses, in case of carbeque" Steve Meade. "in the abundance of water, the fool is thirsty" Bob Marley
Bmike Posted December 8, 2011 Report Posted December 8, 2011 you dont have to fuse it, but fusing it is like having insurance, its there just in case something goes wrong, i have a fuse on every positive power wire in my ride, alt wire and wires that run front to back have 2 fuses each right next to the battery, and 1 next to my amp, better to be safe than sorry, as far as how big of a fuse just a little over the alt rating would be fine. if you ever decide to upgrade your alt then you can put a bigger fuse. 2007 trailblazer lthead unit- pioneer p4300dvd crescendo ft-1 supertweeters pioneer m650 pros audiocontrol 2xs crossover Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
bumonskateboard6 Posted December 8, 2011 Report Posted December 8, 2011 I fuse to the specs of the wire since it's what will burn. OFC 1/0 at 300amps CCA 1/0 at 250amps and so on... Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
mattc3366 Posted December 9, 2011 Author Report Posted December 9, 2011 Alright thanks guys! I got an extra kicker fuse that's 200 amps I just need another holder. Would that work fine? Seems like it would be roughly in between the alt out put and wire specs subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch
Cardboardcat15 Posted December 9, 2011 Report Posted December 9, 2011 Alright thanks guys! I got an extra kicker fuse that's 200 amps I just need another holder. Would that work fine? Seems like it would be roughly in between the alt out put and wire specs Fuse the wire, not the equip. Having a fuse rated more than what the wire will handle defeats the purpose of a fuse. You should be fine with your fuse. Just always remember to fuse according to wire. is it CCA or OFC? My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
mattc3366 Posted December 9, 2011 Author Report Posted December 9, 2011 Its ofc cadence 1/0 subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch
MIKE-2U Posted January 4, 2012 Report Posted January 4, 2012 fuse it 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
