SlamminBeats Posted December 10, 2011 Report Share Posted December 10, 2011 what type of electrical would i need to run 2 T1500s? have a kinetik 600 and 1800 2/3 big 3 done (going to finish the third) 0 gauge going to fix my ground in rear bank to 0 gauge what else might i need? Quote Link to comment Share on other sites More sharing options...
nbshazeezee Posted December 10, 2011 Report Share Posted December 10, 2011 A new alternator Quote Ye dig, getting loud off little (2) AQ HDC3 12 AQ 2200D - Replaced it, Works great AQ4x90 JBL 662s 2 ways (2)XS 5100r under the hood & A 170amp alt Link to comment Share on other sites More sharing options...
412 CVX Posted December 10, 2011 Report Share Posted December 10, 2011 If your car dies, then your electrical support needs improvement wish i was more familiar with the Kinetik line. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
SlamminBeats Posted December 10, 2011 Author Report Share Posted December 10, 2011 why would i need a new alternator? cant i just add batteries? Quote Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted December 10, 2011 Report Share Posted December 10, 2011 adding batteries can only do so much on a stock alternator..x2 on a new alt..less strain on your batts and less chance of damaging equipment due to voltage drops Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
tlee2 Posted December 10, 2011 Report Share Posted December 10, 2011 add a hc2400 to what you got and if you know what your doin youll be fine Quote 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333 Link to comment Share on other sites More sharing options...
1988JimmyRE Posted December 10, 2011 Report Share Posted December 10, 2011 Depends on your current alternator 100 batteries will do the job sure but only till they go dead lol. Quote BUILD LOG-->1988 S15 Jimmy V8 4x4 2 15" RE Audio<--BUILD LOG Link to comment Share on other sites More sharing options...
SlamminBeats Posted December 10, 2011 Author Report Share Posted December 10, 2011 yea thats true, whats the price rang for an alt? any way i can get one for 300? or no chance on that? Quote Link to comment Share on other sites More sharing options...
miniSPLlancer Posted December 10, 2011 Report Share Posted December 10, 2011 why would i need a new alternator? cant i just add batteries? No matter how many batteries you have you still to charge them, a H/O alt will take the brunt of the power and you're not at full tilt it'll be able to charge those batteries you have Quote 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals Link to comment Share on other sites More sharing options...
getlocivic Posted December 10, 2011 Report Share Posted December 10, 2011 depending on where you go on how much a alternator will cost.. there is MECHMAN..SINGER alts dc power.. dbelectrical company on ebay called HI AMPS.. i would do a 200 or 220 amp alt using them 2 batteries u already have..and ADD another 1800... 1 more run of 0 gauge and ull be set for sure Quote Link to comment Share on other sites More sharing options...
