Funny SP4 preview (Lols to be had)
KHRISS
that was funny in montebello hills david hey your a good artist i wallpaper the one with the pen you got talent keep it up
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
I added to dudes harrassment. My YouTube is 1SikMag. I actually seen it a couple days ago & confused the shit outta me. I was set on buying these but now I don't know. Thinking maybe BTL's now.. I agree- Fi needs to clear some stuff up about the sub. New doesn't always = better.
TEAM Fi CAR AUDIO/ TEAM CRESCENDO AUDIO
Bagged '06 Dodge Magnum R/T "WICKED WAYS"
-4 Fi SP4 18's (4th Order)
-2 Fi SSD 10's (midbass)
-4 Diamond Audio D6 Comp Sets
-1pr. Crescendo FT-1 Supertweets
-Dual Alts -6 XS Power Batts
-4 Crescendo BC3500d's (subs)
-1 Crescendo BC2000d (10's)
-1 Crescendo c1100.4 (comps)
I do not understand what FI needs to clear up.
from fi's forum
SP4 Heavier
SP4 More mounting depth
SP4 4" coil vs 3" on N2
SP4 10" spider and higher mechanical linearity than N2
SP4 More long term thermal stability
SP4 Sealed capable vs N2 ported only
N2 More motor force
N2 Inductance ring that balances the inductance swing better
SP4 Slightly lower overall inductance than N2
N2 Well... its cool because its Neo
N2 It's expensive because its Neo (and constantly increasing in cost)
SP4 Slightly higher Xmax (coil limited)
SP4 Lower FS for those that think it matters
In general we created the N2 as the replacement for the older generation BTLs. We have seen the direction people are going with the BTLs and arranged the N2 specs to be closer to intended applications (huge, deep hitting, daily setups). Then creating the N3 to fill the void for the high motor force applications like extreme SPL or simply those that like that "sound".
The SP4 pushes things a little further in the daily driver direction. While the N2s have proven to work well in 4th orders, they simply don't in sealed. The SP4 does just that, and a little better than the N2 in 4ths. It still works great in ported, with the ability to have a heavier peak down low as well.
In testing it is a very solid sub that can take quite a bit of abuse. While not needed (none of the original test drivers we built had it) we do have the option for spaced spiders (2 on the top and 3 on the bottom) with a 1" ring between. In this configuration we have hand sewn on leads in between the spiders. In its standard configuration with 5 spiders and the gapped cone, it is a very stable platform (not a triple jointed sub. The cone is spaced about 1.125" from the top of the spiders. This stabilizes the coil better than the standard triple joint and is what we are doing on the standard versions of the SSD, Q, and BL drivers now).
So which is better? I dont know...lol If you need every bit of weight savings you can find, then the N2. If you are tech oriented and have to have innovation, then the N2. If you need an even more abuse tolerant speaker then the SP4 is for you. If you want big, SP4. Sealed, SP4. Even more thermal stability, SP4. They each have their merits. Choosing the "better" driver is up to your application.
I think the SP4 is in keeping with the times and applications people are heading towards. High excursion, stability, and thermal power handling... albeit at a cost of weight and depth over the N2 series.
here is page http://www.soundsolutionsaudio.com/forum/topic/52795-sp4-vs-n2/
edit: pretty clear to me
Maybe its just me but the only differences i see vs the N2 is handles more power, heavier, works in sealed & gets louder down low.. I miss anything?
higher xmax and cheaper but yea bout got it :good:
edit: and the sealed thing is mostly to make it good for 4ths
like what?
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
X 2
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
