67 Camaro. The blue bomber *EDIT* Now the green machine NOT DONE! Final edition
Nice Bill. You've never failed to impress me with all your work. :good:
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
Thanks. Trying new stuff is fun when it works out :D
Ok, so to make the rings a few sizes were needed.
First I had to build up 3/4 to get over the bump out for the speaker in the door. I then added 1/4 over the top with the ineer hole about 1/2" smaller then the 3/4 ring.
I then glued thos 2 together to make the outter ring and wrapped them in carpet. I wanted to wrap them in vinyl, but it was too much of a strech to have them work out. At least for my skill level in wrapping.
I then made the inner ring using 1/4 board and making the outer part 1/8" smaller then the inner ring of the outside ring. Then cut the inner part the same size as my speaker opening. I wrapped this in vinyl to give ut a 2 tone look.
You can see here the 2 rings before the inner ring was wrapped.
At the same time I cut the inner rings, I also added plexi for the led lighting. Then added a black painted ring to disfuse the light in the right direction.
Once all the rings are ready I stacked them in one layer at a time and glued the edges to hold them in place.
I tape the plexi led strip and backer together with black tape. this keeps it all together and helps the light only show where you want it.
Little test fit to make sure it works and its ready to by added to the door panel.
Wow! I'm digging all the led lighting and those door panels. Can't wait to see the door panels finished. Good work.
Should have them finished tonight. had an idea late last night to add to the panels. :ninja:
LOVE the door speaker rings with the LED light never would think of little things like that, makes it look a lot more detailed as well.
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
Really nice car and an absolute clean built! Great job. Did you mowed the lawn yet?
I mow that section once a year whether it needs it or not
Jjust empty your dust collector on the grass..... lol... looking good as always.. hurry up and make room for that next build
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
i couldn't agree more. :drinks:
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
