Hey all, I'm building a system for my room and need some advice on what brands of cables and wires to look at, and where to buy from. I need 2 cables that have a male 3.5mm connector at one end and left/right RCA connectors at the other, one 3ft. and the other 12ft. I'm thinking about taking out the wiring that comes prewired to the Bash 300W amp I'll be using and wiring in some 8 or 16 gauge. Lastly, I need some 8 or 16 gauge (which would you recommend) to run from my high-level amp to my coaxial speakers. Thanks
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
I'm gonna be using this amp http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-750 and there are connector leads in the circuit board that connect to the wires that run to the woofer. Taking these out and hardwiring the woofer would be better (although just a little bit) and would make one less place for connections to go wrong or disconnect or fail on me
just went on knu's website....wondering if there's really a difference between power and speaker wire. The 8 gauge i think i'd wana use (for the woofer/amp) is labeled as power wire but should i find "speaker" wire instead?
  • Who's Online   1 Member, 0 Anonymous, 1626 Guests (See full list)
