BFF Larry Posted December 12, 2011 Report Posted December 12, 2011 When driving, only when accelerating pretty hard or braking pretty hard, I can hear squeaking noises audible sounds like its coming from the wall. When I was building it, I could ram the sides,back, port and top without any noise and no budging, only thing would move is the car. Does anyone else get these little squeaky noises? It's only noticeable when the Windows up, no music, basically dead silence. The noise is really quiet, just enough to barely notice it Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
SnowDrifter Posted December 12, 2011 Report Posted December 12, 2011 It could be a tiny bit of frame flex or something in your car. How did you secure your wall? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
extremeauto Posted December 12, 2011 Report Posted December 12, 2011 When driving, only when accelerating pretty hard or braking pretty hard, I can hear squeaking noises audible sounds like its coming from the wall. When I was building it, I could ram the sides,back, port and top without any noise and no budging, only thing would move is the car. Does anyone else get these little squeaky noises? It's only noticeable when the Windows up, no music, basically dead silence. The noise is really quiet, just enough to barely notice it i get a lil noise but my truck made noise b4 i put the wall in...more than likely its rubing somewhere when u turn or hit bumps and the body roll's & flex's ....take a look around it to be sure if its been doing it for awhile ther should be some scuffing where its rubbing and u can go from there 1995 Honda passport 3.2 4x4 Frankenstein on a budget ballistics sound deader (roof only so far) kenwood mp3 usb audio control 3 (upgrading) hifonics mx-3 3 sets of massive px5 5.25s 3 sets of massive tweets phonix gold 5.25 componets x2 massive nx4 nano 200x4 mids sony xplod 600x4 watt high's 2 Fi bl fully loaded box walled @31ish hz 13.2 cube box/wall massive DB8000 Excessive amaperge 250 amp alt wir extrnl regulator daul runs of xs power xpflex 0 gauge big 3 raptor 0 gauge power/ground wire full run suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt scytek galaxy 2way alarm still upgradeing!
getlocivic Posted December 12, 2011 Report Posted December 12, 2011 i had the same problem when i walled my civic.. just a faint squeaking on luttle bumps etc.. found out it was actually the side trim panels..and the foam wasnt against it yet.... added 3 more cans of foam and fixed everything i made a 2x4 "floor" screwd down with lag bolts and then my enclosure on top of that secured with lag bolts also
BFF Larry Posted December 12, 2011 Author Report Posted December 12, 2011 i had the same problem when i walled my civic.. just a faint squeaking on luttle bumps etc.. found out it was actually the side trim panels..and the foam wasnt against it yet.... added 3 more cans of foam and fixed everything i made a 2x4 "floor" screwd down with lag bolts and then my enclosure on top of that secured with lag bolts also you just helped me narrow it down haha, thanks guys for all your replies and help. i bet its not the box, but the "floor" its a bunch of 2x4 framed together but is bolted down on only four spots, the four seat belt bolts. maybe its just the floor squeaking alittle, because i can push on the baffle, sides, and back but no squeaky noises. Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
