ok i got two 18" Fi Q's in a 15cuft box in my ext cab. tuned at 30hertz. i am running them off one Alpine MRP-2000 at the moment (which is 2000 @ 2 ohm), but I wired the (dual 1) subs in series-parallel for a 1 ohm load, which is 'unhealthy' for my amp. So whats the best one amp set-up for my system? or should i get another alpine and wire them at 2 ohms a piece to separate amps? really wanting a single amp setup though (and may possible upgrade to BTL's later, so i need some extra POWAA down the road!)
I have mine on a Soundstream TX12600.. it pushes them pretty damn good and is .5 ohm stable. Buy one of those and then if you upgrade to (2) BTLs then you can just buy another amp and run one amp to each sub.
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
fosgate T2500BDCP
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
ok thanks guys. . . and also, my subs are bottoming out on me now anything below 30 and im wanting killer lows in the 28-23 range. tips on achieving this? i have four 4in PVC pipes, two on both sides, cut to the correct length (based off 12volt.com). could it be the amp? box? port? . . . . .
That's not near enough port area for a 15 cuft box..... Give me your dimensions on the box and I'll give you some suggestions....
Edit: if you are at 15 cubes then you would need something like 12 4" ports to be in the right port area range....lol that would be super innefficient imo. Maybe more like 5 6"?
Or 3 8"
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Or 3 8"
yeah i wwas thinking that. . . this is just a "first run" box so im still experimenting.
