Now I'm only a noob to car audio but I have somewhat of a clue do go easy on me for asking this but I wanna know all about overpowering speakers and woofers
I know it's possible that's been proven time and time again but how is this done how does a sub rated at 600 watts run on 2000 watts of power
Can some1 help me out here
It is being given only CLEAN power and done by someone who's experienced.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
it sounds like ur talking about sundown...the main reason u can over power those is they are built VERY WELL and underrated ...like the guy above me said it has alot to do with using clean power..if you send it clipped/dirty power its gonna fry the sub no matter what its power rating is...anther key is your box size and design...i my self know a lil about overpowering subs safely but its truly never a good idea unless its a sundown or another well built sub...other than that some1 who knows more should step in and explain whatever i missed
also i think u need a smaller encloser to use more power
Edited by extremeauto
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
Close I was on about Skar audio... Cause they are making a 4500.1 amp so I wanted to get 1 when they come out and put it to work on 4 Vvx 15's and before I lay down the cash I want as much knowledge as possible
I run my 2 SA15's on 3k daily 1 ohm so their taking more than double what their rated for, you have to take into consideration box sizing port volume ect, making the box bigger will lower the thermal level lots of factors play into what is called overpowering.
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
the vvx series i have seen run on about 1000 rms a piece safely on a UNCLIPPED signal. they are another brand that is underrated. they wont tell you to run that much to them probably but if i were you i would talk to kevin from skar audio or maliboom. they both are involved with skar audio......i believe kevin is the owner but i could be wrong. they will be able to answer any question about skar subs and amps.
good luck :)
-jarrid
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
good luck :)
-jarrid
Thank you very much mate exactly what I wanted to know :)
You also have to think about rise. Let's say you have 2 Sa subs, rated at 600 a piece , you put a sundown 3k on them, final load is 1 ohm, depending on box and such your rise might be 3 ohms on music so that's around 1000 watts ur subs are getting, so you'll never know unless you clamped the amp, see were you rise at. Adjust to that, bingpadaboom !
  • Who's Online   0 Members, 0 Anonymous, 2133 Guests (See full list)
