2 xl15's 4thorder wall. new wall starting page 7
okay well onto the tuning issue.
the subs are unloading at certain frequencies.
so after talking to mr mike singer im making a few changes to the box. ultimately building a new box.
and not just a 2:1 but a 4:1 ratio if i can squeeze that together.
so onto the destruction of my current box. didnt get much work in tonight but hopefully i can get some more done tomorrow.
removed the front seat to give me some breathing room to work around everything.
moved that out of the way. then took everything out.
pulled off the front.
one sub out
had to move that top 2x4 to pull the screws out of the side of the bend in the port
smacked out the 1 inch dowl rod with a hammer. pretty easy since i couldnt pull that top screw out. gonna grind it off
after both subs out i prettty much just kicked the shit out of the lip to break the glue. here it is gone now
one of the xls' just chilin
thats all for now pics wise. ill throw up the ideas im changing tuning wise and what specs im given.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
origninal 4.75Hx 40.5 x 20D external 7.75 comes to 27.88per 7.51^3ft net and 44.13hz
okay.. well what im planning is decreasing port area.
only removing lip. 4.75hx 40.5 w x 15.25d 8.32^3ft net 23.12 per at 46.30hz
removing that lip and adding a baffle to the top of my port and a baffle to the sides. (4Hx 39.25w x 15.25 D) with 7.75 external it comes to 18.78 per 8.36^3ft net and 42.83hz
thats kind of where im at right now. going to reinstall everything tomorrow and play around with it.
also im decreasing the sealed side from 1.77 to ~1.5^3ft
hoping that will help out tremendously
any input is appreciated. thanks guys
1.5 per 15 or total?
per 15.
  • 1 month later...
  • 4 months later...
well i havent really been on here in a long time. been occupied with work and school trying to get my grades up. i havent had much time to really do anything with the system.
anyways planning a 4/1 fourth order with the two xls then later moving up to 18's in a 2.5/1
so ive pretty much ripped out all of the old stuff.
ive built a shell so far that has about 23.4 cubes of air space. obviously too much to use a 4/1 ratio.
so ive started to build the sealed side big enough to fit the 18's so im not going to have to do a total rebuild. just remove some displacement and bam room for 18s
sealed side is gonna be about 2.9~ cuft for both the 15's including the displacement to make the net volume smaller. after everything is removed it should be about 2.25 cuft per 18. (still kind of wondering if thats suitable) so im open to opinions <<< i feel like that does not make any sense lol but i cant figure out how to word it.
Im trying to upload some pictures of what i have now but my phone has zero service (AT&T for the loss) so pics will be up tonight.
building new door panels, along with a center console with 4 pwx 8's from crescendo and two of the new skar super tweeters.
so only a single mp8 and an xst2 super tweeter in each door.
gonna do a removable port this time and the whole front plate will be removable for now until i do the 18's then itll all be sealed up.
trying to figure out a way to add some displacement to the ported side that i can pull off later for the 18's
anyways only so much i can do without pics. but those will be up later tonight.
One way to add displacement is simply to build a little box, seal it up and screw it into place somewhere out the way... or for easier laborations - cut out pcs in brick or MDF that are get like .1 cf... and stack enough until u know where u want to be.
cheers, zrkie
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
Closing up the sealed side makes sense to me to control excursion, but opening up the vented side to me doesnt make sense??? I always thought the ported side controlled sub movement as well, and makes for a even more peaky response around tuning?
F967DB9B-2C55-48E2-822D-39C45C9FCF9F-766
everything out
starting some new reinforcement
C233547C-283F-4C50-8123-D4ED3A1D2BEA-761
760980C0-0F99-4BA5-A5B7-7DDB7257FF36-766
8E220B0B-5CF4-4A67-B3DA-EAD15E597419-761
62C12556-2399-438D-A538-A6EE4CB69E7C-371
starting the shell
6449ADC1-725A-4DC0-9036-3625E15191F5-766
AE0DA82E-78F9-41F8-9C89-1AADD2597119-371
heres some miscellaneous pics
B8DFBB08-8763-42C1-A98A-78AE45D8E4C5-371
heres an amp rack for the tool box my dad started on.
1747EF4F-D18D-4283-99B9-A32D7EC790AF-371
this is kinda where im at right now. between school and work i can only do stuff on the weekends.
thanks for the feed back guys.
oh and heres all the crap piled up
C5D89C5D-CFD7-4E51-B0E0-522B415F506C-371
