SlamminBeats Posted December 15, 2011 Report Posted December 15, 2011 (edited) is this correct? the amp can handle 2 ohms, i assume all the speakers are 4 ohms all pioneer D series. the deck is already wired in and so are the 6x9's and 5.25 with one set of tweets. now i want to add that second set of components. but is that the correct way of doing it? i definitely do not want to run another wire from the new set to the amp, so i tagged it into the existing 5.25's have i made an mistakes thanks in advance! Edited December 15, 2011 by SlamminBeats Quote
Nine8SST Posted December 15, 2011 Report Posted December 15, 2011 (edited) Yes.....run to the xovers....not sure what you have going on connecting the 2 midbass' together like that. Edited December 15, 2011 by Nine8SST Quote 1998 SS/T Ram Build Log - Kenwood KVT-514 and KNA-G510 Navigation - 2 DC Level 3 12" - Components??? - Sundown ??? - Sundown??? - Knu Konceptz - Second Skin Dampy Pro - XS D6500
SlamminBeats Posted December 15, 2011 Author Report Posted December 15, 2011 so i have to run a pos and neg wire from the front 2 channels of the amp to the new crossover to make this work? can i just some how tag the speakers together or maybe the crossovers? it would be way easier to just tag them at the doors ya know? Quote
412 CVX Posted December 15, 2011 Report Posted December 15, 2011 clean that up and it will make a lot more sense. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
MrSkippyJ Posted December 15, 2011 Report Posted December 15, 2011 Don't wire the speakers together after the crossovers. You start changing the crossover points if you do that. Wire the inputs of the crossovers together then leave the crossover outputs normal. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
pa-pa-platypus Posted December 15, 2011 Report Posted December 15, 2011 bump bump just a heads up..dont bump so fast..patients is a virtue Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
Nine8SST Posted December 15, 2011 Report Posted December 15, 2011 If you look you will see how I edited your picture. Quote 1998 SS/T Ram Build Log - Kenwood KVT-514 and KNA-G510 Navigation - 2 DC Level 3 12" - Components??? - Sundown ??? - Sundown??? - Knu Konceptz - Second Skin Dampy Pro - XS D6500
SlamminBeats Posted December 15, 2011 Author Report Posted December 15, 2011 (edited) this is how one of two front channels would look then? crossovers wired together, then one gets wired to the amp. And currently one is wired to the amp so i can tag the new one into the old one? Edited December 15, 2011 by SlamminBeats Quote
MrSkippyJ Posted December 15, 2011 Report Posted December 15, 2011 assuming that the components are 4 ohm, then yes. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
