XS Power
Ok. Need some opinions on how many D3100's I will need. Here's my setup, etc..
YellowTop Primary batt. (mids & highs will get power from this).
Dual Alts (12v, 1 270amp & 1 350amp, both will charge batts).
Sub Amps- 2 Soundigital 5k's.
Daily Rap/ R&B (mostly while car is running).
Space isnt a problem.
I already have an idea on how many but I just wanted 2nd opinions. Also, would it be better to wire as 2 seperate banks of batts for the 2 sub amps or 1 big bank, or does it even matter? Thanks in advance Nathan & guys...
Edited by DreDay256
TEAM Fi CAR AUDIO/ TEAM CRESCENDO AUDIO
Bagged '06 Dodge Magnum R/T "WICKED WAYS"
-4 Fi SP4 18's (4th Order)
-2 Fi SSD 10's (midbass)
-4 Diamond Audio D6 Comp Sets
-1pr. Crescendo FT-1 Supertweets
-Dual Alts -6 XS Power Batts
-4 Crescendo BC3500d's (subs)
-1 Crescendo BC2000d (10's)
-1 Crescendo c1100.4 (comps)
i would do 1 big bank man, you dont want to drain the batts at different rates if they are strapped to the same alts
Ye dig, getting loud off little :D
(2) AQ HDC3 12
AQ 2200D - Replaced it, Works great
AQ4x90
JBL 662s 2 ways
(2)XS 5100r under the hood & A 170amp alt
This could be true & I thought about that as well... any other opinions on this anyone?
I would recommend running 4 D3100 in one bank, but I would suggest trying this in steps. I would suggest getting 2 D3100 to start with and see how they perform under your use. 2 probably will not be enough, but you never know. Then if 2 doesn't keep you in the voltage range you want to be in I would suggest getting a third D3100 and see how that works for you.
This way if you find that 2 or 3 does fine for you, then you dont have to spend more money on batteries.
NATHAN FOR PRESIDENT!!! :yahoo:
Ok. Thanks Nathan. That sounds like a plan. I'll try that..
If anyone is running a couple SD5k's or a single SD5k, I'd like to hear what you guys are using & what your voltages hold at...
With the way it is looking for the next election I might have a chance............lol
^^LOL..
Id vote for u Nathan!
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
id vote for you nathan :D
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
  • Who's Online   0 Members, 0 Anonymous, 2722 Guests (See full list)
