What's worse, too much, or too little port area?
Let me start off by saying my original box design did not have an aero port, but there were complications and i ended up using a 3" diameter port my friend had. Needless to say i made a huge mistake. Using torres' Box designer, i found that my current setup is only giving me 7.07sqin of port area. The sub i am running is an AQ SDC-2.5 15", which needs 16sqin of area. My problem is between the 4" and 6" aero port. The 4" provides me with 12.56sqin, and the 6" provides 28.26. What do I do? Please help!!!
2001 Subaru Forester
-front to back-
pioneer AVH-p4300
pioneer ts-1684 6.5" front doors
pioneer ts-t100 7/8" front doors
AQ-PA-B25 super tweeters rear doors
pioneer gm-6500f 4channel
Audioque 750mono
2 12" solo baric wired to .5 ohm
Prefab 3.56 net cf Kicker box tuned to 34hz
Mechman 160amp alt
0guage from alt to back seat
Power use comes into play with port area too. What power is that sub seeing in its current environment?
Would be easier for people to give you a accurate answer with ALL of the info needed..
I will say though, 9.5-10 sq per cube is about the smallest i every try to use with a normal type sub in a small enclosure running 1.5 to 2x rms power.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
You have a 15" sub, so hopefully your using more than one cubic foot of air space. I dont have torres' calc on this computer so i can't check it out.
But when your using aero ports you don't need the typical 12-16 sqin per cube. You can use 9-13 sqin per cube.
You must remember that the "16sqin" is PER cubic foot of air space after displacements and not including the port itself.
But to answer your title, too much can cause unloading and lower the power handling of the sub, and potentially cause premature failure.
Too little and it will cause port noise, and will not sound good.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
As kandi already said, Power comes into play in both the port, AND the size of the enclosure itself... More is less... and less is more... LOL...
Well, im running the AQ750 @2oms so that's 500rms. My box is 3cubes on the nose after all displacements.
-front to back-
pioneer AVH-p4300
Audioque 750mono
Mechman 160amp alt
I guess my final snag is to either get the 6" or the 4" aeroport. I'll find some pics of the box in car to show why it is the size it is.
-front to back-
pioneer AVH-p4300
Audioque 750mono
Mechman 160amp alt
when youre figuring in how much port area you need its PER cube of the box...so if you have a 3 cube box (this is just an example to help ya) to get the 12-16 you could multiply 12x3 to get you 36 inches of port area needed..for 16 it would would 16x3 to give you 48 and so on...hope that helps :pardon:
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
  • Who's Online   0 Members, 0 Anonymous, 1110 Guests (See full list)
