g2shuck Posted December 24, 2011 Report Posted December 24, 2011 I am getting ready to buy a sdc 2.5 sub. I have a box that was built professionally that nets right under 4 cubic feet after sub displacement, braces, and ports. It is tuned to 36hz. will this box be good for the sdc 2.5 15 and also I have an amp that puts out 900 watts rms at 2 ohms. Can the sdc 2.5 handle 900 daily if i set the amp correctly with a multimeter to make sure there is no clipping 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
dtleonard26 Posted December 24, 2011 Report Posted December 24, 2011 That box is almost dead on there specs should do well 900 watts? I can see it Bagged 83 C10 89 K1500
AB18VFL Posted December 24, 2011 Report Posted December 24, 2011 be easy on the gain and i dont think you should have a problem. I'm running a rockford p3 12 right now on 1000rms and i usually dont have problems on daily music. coil gets a little warm though. SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!! 2005 Subaru Impreza My build log. Head unit- Kenwood Excelon KDC-X695 Front doors- Rockford Fosgate 6.5" Prime components Rear doors- Rockford Fosgate 4" Punch coaxials Sub amp- Audiopipe AP18001d Subs- Two American Bass TNT 10"s Box- 2.6 cubes @ 34hz, 36in of port Big 3 & run of Raptor 1/0 to rear powercell TEAM 808 UPSTATE NY. Can it be heard 2 blocks away, thats how i rate systems.
g2shuck Posted December 25, 2011 Author Report Posted December 25, 2011 thanks guys I just wanted to make sure I would not hurt anything this is my first "real" sub lol 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
dtleonard26 Posted December 25, 2011 Report Posted December 25, 2011 They get loud I have one in a 4th order Bagged 83 C10 89 K1500
pa-pa-platypus Posted December 25, 2011 Report Posted December 25, 2011 amp should be a good fit for these subs.. i had my pair on 1000 a piece and they took with no problem lol hell they barely would get warm unless i was drunk and turned the volume up to high This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
mattc3366 Posted December 25, 2011 Report Posted December 25, 2011 Use a dd-1 or o scope to set the gains subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch
fecupe2001 Posted December 25, 2011 Report Posted December 25, 2011 Box size look good I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
I am Poncho Posted December 25, 2011 Report Posted December 25, 2011 you should be perfect in that, love my 2.5s. i had them in the same amount of space with 12" of port but mine were tuned down to 32. make sure you break that baby in a littl before throwing the whole 900 at it. if your head has a sub control +/- just set it for 0 with dd1 then crank it down on the head to like -5to-10 play that for a few days put back to zero. enjoy. OLD BUILD LOG: http://www.stevemeadedesigns.com/board/topic/166273-poncho-designs-trailblazer/ New car, new build coming soon...
